Home > Forums > Software User Forums > SU2 > SU2 Installation
Parallel Build from source of SU2 6.2.0 on Linux Manjaro
Old   April 29, 2021, 12:40
Default Parallel Build from source of SU2 6.2.0 on Linux Manjaro
AeroEnthusiast is on a distinguished road
Hi there,
I am trying to install the specifically needed SU2 6.2.0 FALCON on Linux MANJARO. I followed the instructions from https://su2code.github.io/docs/Parallel-Build/ which basically states to do:
1) ./bootstrap
2) ./configure --prefix=/path/to/install/SU2 CXXFLAGS="-O3" --enable-mpi
--with-cc=/path/to/mpicc --with-cxx=/path/to/mpicxx
3) make -j 8 install
And on the last step, after it runs for a lil bit, this bug appears. Even though I have submitted a report on ARCH LINUX, I could progress further if anyone has experienced this before and know how to get around this issue?
Thank you!
AeroEnthusiast is offline   Reply With Quote
SU2 parallel install build from source failed steadyman SU2 Installation 19 April 25, 2021 16:50
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
