Home > Forums > Software User Forums > SU2 > SU2 Installation
There some errors when I first running the tutorail
Like Tree1Likes
  • 1 Post By Li_Desheng
Old   March 9, 2023, 09:43
Post There some errors when I first running the tutorail
Li_Desheng
Li_Desheng is on a distinguished road
When I first run the Inviscid_Bump, there are some errors:
orted: symbol lookup error: /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_pmix_ext3x.so: undefined symbol: pmix_value_load
[DESKTOP-823G5TH:17385] [[INVALID],INVALID] ORTE_ERROR_LOG: Unable to start a daemon on the local node in file ess_singleton_module.c at line 716
[DESKTOP-823G5TH:17385] [[INVALID],INVALID] ORTE_ERROR_LOG: Unable to start a daemon on the local node in file ess_singleton_module.c at line 172
It looks like orte_init failed for some reason; your parallel process is
likely to abort. There are many reasons that a parallel process can
fail during orte_init; some of which are due to configuration or
environment problems. This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
orte_ess_init failed
--> Returned value Unable to start a daemon on the local node (-127) instead of ORTE_SUCCESS
It looks like MPI_INIT failed for some reason; your parallel process is
fail during MPI_INIT; some of which are due to configuration or environment
problems. This failure appears to be an internal failure; here's some
additional information (which may only be relevant to an Open MPI
developer):
ompi_mpi_init: ompi_rte_init failed
--> Returned "Unable to start a daemon on the local node" (-127) instead of "Success" (0)
*** An error occurred in MPI_Init
*** on a NULL communicator
*** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
*** and potentially your MPI job)
[DESKTOP-823G5TH:17385] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not
able to guarantee that all other processes were killed!
I'm new to SU2 software and CFD and I don't know how to solve this problem. Thank you for your help!
Li_Desheng is offline   Reply With Quote
Old   March 9, 2023, 14:21
bigfoot
bigfootedrockmidget is on a distinguished road
Looks like openmpi was not correctly or completely installed. Please reinstall openmpi and make sure it works correctly by running a simple openmpi test.
bigfootedrockmidget is offline   Reply With Quote
Old   March 9, 2023, 21:29
Post
Li_Desheng
The problem is indeed openMPI. The 5.0.0 version I installed before may be unstable.Later, after reinstalling the now stable distribution (4.1.5), the computation was fine.Thank you for your help
Errors when running waves2foam JinshiC OpenFOAM Running, Solving & CFD 3 January 18, 2022 10:45
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
