There some errors when I first running the tutorail |
March 9, 2023, 09:43 |
Li_Desheng
Rep Power: 3 |
When I first run the Inviscid_Bump, there are some errors:
orted: symbol lookup error: /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi3/mca_pmix_ext3x.so: undefined symbol: pmix_value_load [DESKTOP-823G5TH:17385] [[INVALID],INVALID] ORTE_ERROR_LOG: Unable to start a daemon on the local node in file ess_singleton_module.c at line 716 [DESKTOP-823G5TH:17385] [[INVALID],INVALID] ORTE_ERROR_LOG: Unable to start a daemon on the local node in file ess_singleton_module.c at line 172 -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): orte_ess_init failed --> Returned value Unable to start a daemon on the local node (-127) instead of ORTE_SUCCESS -------------------------------------------------------------------------- -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: ompi_rte_init failed --> Returned "Unable to start a daemon on the local node" (-127) instead of "Success" (0) -------------------------------------------------------------------------- *** An error occurred in MPI_Init *** on a NULL communicator *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) [DESKTOP-823G5TH:17385] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed! I'm new to SU2 software and CFD and I don't know how to solve this problem. Thank you for your help! |
Errors when running waves2foam | JinshiC | OpenFOAM Running, Solving & CFD | 3 | January 18, 2022 10:45 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
