January 6, 2017, 08:36 |
Apply SU2 in my own air-foil and wing
João Lourenço
Rep Power: 9 |
Hi community,
I'm trying to use SU2 to study my own air-foil and wing. I had install the last version of SU2 in ubuntu and I did some tutorial. In this moment I want to test my air-foil in SU2 but I don't know how I do. How I put my air-foil in SU2 program? Is it possible SU2 generate an automatic mesh for my cause? Thanks a lot, João Lourenço Student of Aerospace Engineering |
January 9, 2017, 02:55 |
Ole Burghardt
Rep Power: 10 |
there is no mesh generator included in SU2. The standard way to import an own mesh into SU2 is to export it as a CGNS file, which then can be read by SU2 by setting the option Code:
MESH_FORMAT= CGNS Best regards, Ole |
January 11, 2017, 05:38 |
SU2 in my airfoil - Pointwise program
#3 | |
João Lourenço
Rep Power: 9 |
If I understand I need to use o program to generate my own mesh in my profile, export it as a CGNS file and then put in SU2 program, right? I'm try to install pointwise but I can not find the program. Someone can help me? |
January 11, 2017, 06:08 |
#4 | |
Ole Burghardt
Rep Power: 10 |
But let me just mention that by now there a mesh generators that can directly export the mesh in .su2-format (like gmsh), so in these cases there is no need for the transfer via CGNS. |
January 11, 2017, 09:49 |
#5 | |
João Lourenço
Rep Power: 9 |
Thanks a lot for the help. |
January 11, 2017, 11:33 |
Ole Burghardt
Rep Power: 10 |
Gmsh has very basic functionality, Pointwise is a professional and commercial program. You can't compare them.
There are lots of(!) meshing tools out there. You'll have to try out a few if you have never worked with any of these kind of programs before - each one has it's very own advantages and disadvantages. |
January 12, 2017, 04:09 |
#7 | |
João Lourenço
Rep Power: 9 |
Hydrofoil wing in fluent | wind_tunnel_contraction | FLUENT | 3 | September 30, 2016 09:50 |
Using the wing mesher | GavinB | STAR-CCM+ | 1 | November 20, 2015 01:14 |
