Home > Forums > Software User Forums > SU2 > SU2 Shape Design
Adjoint simulation
Old   March 11, 2013, 11:07
Default Adjoint simulation
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I have downloaded the last version of the solver from svn (here) and I have tried to solve the attached case (NACA0012).
I have tested 2 cases:
1. Mach = 0.15, with incompressible formulation
- the direct solution works very well
- the adjoint simulation fails
2. Mach = 0.8, compressible
- the adjoint simulation seems to work
Why this happen? Haven't you tested the adjoint solution for low Mach numbers?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   March 12, 2013, 01:19
Thomas D. Economon
economon is on a distinguished road
Hi Samuele,
Please check the post I left over in this thread on the topic: http://www.cfd-online.com/Forums/su2...ch-number.html.
Hope this helps!
T
economon is offline   Reply With Quote
Old   March 20, 2013, 11:03
Roberto Pieri
robyTKD is on a distinguished road
Hi everybody,
I discovered that the problem with my mesh was related to elements near leading edge which didn't follow the curvature of the surface of the airfoil. Now results are very good.
I would also like to obtain adjoint solutions: both with drag and lift objective function.
In this case the ROE-2ND discretization gave me strange results (attached below); switching to JST, the solution seems to be better (both cases had been ran with drag obj function).
Problems arise when I want the adjoint solution with lift objective function; the solution is enormously slow (you can compare the residual.vs.iterations in both cases in the figures attached below).
Then I have some questions:
  • attached below you also find the config file, is there something wrong?
  • from my tests, it seems that the code reduces the CFL number when performing adjoint solution, is it right? Improving CFL could help me with adjoint-Lift convergence? If yes, which file should I modify?
http://dl.dropbox.com/u/27047350/Adjoint.zip
thank you in advance,
Roberto
robyTKD is offline   Reply With Quote
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
