December 2, 2015, 14:53 |
Problem Mesh and Optimization
Massachusetts
Rep Power: 10 |
Hello
I need a suggest. I have to run a shape optimization with SU2 and i'm in trouble because i need to build a mesh of a 2D airfoil. I'm in trouble because the only mesh generator i know well is ICEM, and my student version is only for windows, while I've installed SU2 on Linux. I'm also starting familiarize with OPENFOAM. Now i don't know how to obtain a mesh compatible with SU2. Can i generate it by ICEM and then export to SU2? Or is it better learning BlockMesh or Snappy and then change the format? Thanks for help |
December 3, 2015, 05:50 |
Rep Power: 12 |
from ICEMCFD you have to save the grid as CGNS format, while SU2 has to be compiled with the CGNS library. If you want to export a grid in SU2 native format you have to use Pointwise For more info refers to https://github.com/su2code/SU2/wiki/Mesh-File Anyway, in my case I compiled SU2 (release 3) with CGNS_3.2.1 library while exporting from ICEMCFD as CGNS 2.4 |
December 3, 2015, 07:22 |
#3 | |
Massachusetts
Rep Power: 10 |
To save in CGNS format have i only do "save as" and then write .CGNS? |
December 3, 2015, 09:35 |
Rep Power: 12 |
In the tab "Output mesh" -> "Select solver" choose CGNS.
In the same tab select "write input" and pick the CGNS version. As written before I used 2.4 as the others gave errors in SU2, but it's upon the library you compile |
Issue with arbitrary Lagrangian-Eulerian method and mesh optimization | mikolchon | Main CFD Forum | 0 | August 16, 2014 15:50 |
CFD_screening problem for Francis Turbine Optimization | berk can | Fidelity CFD | 3 | February 22, 2014 12:08 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
mesh problem in optimization | zikozaki01 | FLUENT | 1 | May 22, 2012 16:46 |
Mesh smoothing and optimization code? | lakeat | Main CFD Forum | 2 | December 3, 2011 07:39 |
