Why Optimal Shape Design of a Rotating Airfoil (tutorial 8) met divergence? |
November 17, 2016, 10:27 |
Bingfei
Rep Power: 10 |
Hello All,
As I try Optimal Shape Design of a Rotating Airfoil (tutorial 8), it showed it has non-physical points and it diverged. I I entered "python shape_optimization.py -f rotating_NACA0012.cfg -q False" for optimization. I attached configure and mesh file here. And the error is as follow: 802260.070862141.046635147.574381-10000.000000-10000.000000 802270.070862141.045031147.572994-10000.00000010000.000000 802280.070862141.044549147.572567-10000.00000010000.000000 802290.070862141.045506147.573470-10000.00000010000.000000 802300.070862141.046289147.574196-10000.00000010000.000000 802310.070862141.157858147.692308-10000.00000010000.000000 802320.070862141.239897147.771173-10000.00000010000.000000 802330.070862142.549743149.108275-10000.00000010000.000000 802340.070862142.498160149.085855-10000.00000010000.000000 802350.070862142.783924149.366008-10000.00000010000.000000 802360.070862142.383524148.966505-10000.00000010000.000000 802370.070862142.121731148.697318-10000.00000010000.000000 802380.070862141.989612148.562711-10000.00000010000.000000 802390.070862141.917804148.487499-10000.00000010000.000000 ---------------------- Local Time Stepping Summary ---------------------- MG level: 0 -> Min. DT: 1.67123e-07. Max. DT: 0.0057421. CFL: 6. ------------------------------------------------------------------------- ----------------------- Residual Evolution Summary ---------------------- log10[Maximum residual]: 143.591. Maximum residual point 5231, located at (11.3915, 14.0631). There are 326 non-physical points in the solution. ------------------------------------------------------------------------- IterTime(s)Res[Rho]Res[RhoE]CLift(Total)CDrag(Total) 802400.070862141.919205148.488830-10000.00000010000.000000 802410.070862141.890851148.461624-10000.00000010000.000000 802420.070862141.907374148.476271-10000.00000010000.000000 802430.070862141.850338148.419919-10000.00000010000.000000 802440.070862141.920849148.493587-10000.00000010000.000000 802450.070862141.347845147.933063-10000.000000-10000.000000 802460.070861141.243377147.867069-10000.000000-10000.000000 802470.070861141.601230147.898575-10000.000000-10000.000000 802480.070861141.281252147.934883-10000.000000-10000.000000 802490.070862141.419211147.958188-10000.000000-10000.000000 802500.070862141.339054147.971665-10000.000000-10000.000000 -------------------------- File Output Summary -------------------------- Writing comma-separated values (CSV) surface files. Merging connectivities in the Master node. Merging coordinates in the Master node. Merging solution in the Master node. Writing SU2 native restart file. Writing Tecplot ASCII file volume solution file. Writing Tecplot ASCII surface solution file. Writing the forces breakdown file. ------------------------------------------------------------------------- 802510.070864141.364314147.995806-10000.000000-10000.000000 802520.070864141.336538147.943929-10000.000000-10000.000000 802530.070864141.725985148.332103-10000.000000-10000.000000 802540.070864141.350102147.95459110000.000000-10000.000000 802550.070864141.511964148.11914110000.000000-10000.000000 802560.070864141.683121148.30592310000.000000-10000.000000 802570.070864141.874060148.48854910000.000000-10000.000000 802580.070864141.871048148.48667410000.000000-10000.000000 802590.070864141.776553148.38919310000.000000-10000.000000 802600.070864141.660417148.26944410000.000000-10000.000000 802610.070864141.519441148.12146410000.000000-10000.000000 802620.070864141.347365147.94512310000.000000-10000.000000 802630.070864141.133635147.72258810000.000000-10000.000000 802640.070864140.895956147.47376510000.000000-10000.000000 802650.070864140.745786147.19990810000.000000-10000.000000 802660.070864140.505270146.90049210000.000000-10000.000000 802670.070864140.284874146.60089610000.000000-10000.000000 802680.070864140.205566146.38919910000.000000-10000.000000 802690.070864140.411331146.42652710000.000000-10000.000000 802700.070864140.398680146.38738410000.000000-10000.000000 802710.070864140.287615146.36191810000.00000010000.000000 802720.070864142.242658148.30991810000.000000-10000.000000 802730.070864142.135021 148.23228610000.00000010000.000000 802740.070864142.119853148.20461310000.00000010000.000000 802750.070864142.136155148.21911810000.00000010000.000000 802760.070864142.136514148.21933210000.00000010000.000000 802770.070864142.148057148.23146410000.00000010000.000000 802780.070864144.418341150.15343510000.00000010000.000000 802790.070864144.095130150.12161810000.00000010000.000000 ---------------------- Local Time Stepping Summary ---------------------- MG level: 0 -> Min. DT: 1.96599e-07. Max. DT: 0.00548642. CFL: 6. ------------------------------------------------------------------------- ----------------------- Residual Evolution Summary ---------------------- log10[Maximum residual]: 146.338. Maximum residual point 206, located at (12.7485, 15.4103). There are 195 non-physical points in the solution. ------------------------------------------------------------------------- IterTime(s)Res[Rho]Res[RhoE]CLift(Total)CDrag(Total) 802800.070864144.480049150.24787910000.000000-10000.000000 802810.070864144.470469150.26627810000.000000-10000.000000 802820.070864144.348874150.17629610000.000000-10000.000000 802830.070864144.461077150.30676610000.000000-10000.000000 802840.070864144.512907150.362175-10000.000000-10000.000000 802850.070864144.560500150.509304-10000.000000-10000.000000 802860.070864144.540206150.519431-10000.000000-10000.000000 802870.070864144.640407150.702012-10000.000000-10000.000000 802880.070864144.792297150.905065-10000.000000-10000.000000 802890.070864144.884054151.01332610000.000000-10000.000000 802900.070864144.719157150.82559610000.000000-10000.000000 802910.070864144.676127150.78552710000.000000-10000.000000 802920.070864144.713505150.81388510000.00000010000.000000 802930.070864144.727893150.82528210000.00000010000.000000 802940.070864144.751866150.84807710000.000000-10000.000000 802950.070864144.787424150.87300810000.000000-10000.000000 802960.070864144.810048150.88856310000.00000010000.000000 802970.070864144.880866150.92778710000.00000010000.000000 802980.070864144.945385150.97423510000.00000010000.000000 802990.070864145.016040151.02283810000.00000010000.000000 803000.070864145.206372151.18454510000.00000010000.000000 803010.070864145.527455151.50660610000.00000010000.000000 !!! Error: SU2 has diverged. Now exiting... !!! Traceback (most recent call last): File "shape_optimization.py", line 154, in <module> main() File "shape_optimization.py", line 99, in main options.quiet) File "shape_optimization.py", line 137, in shape_optimization SU2.opt.SLSQP(project,x0,xb,its,accu) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/opt/scipy_tools.py", line 128, in scipy_slsqp epsilon= eps) File "/home/gentai/Enthought/Canopy_64bit/User/lib/python2.7/site-packages/scipy/optimize/slsqp.py", line 206, in fmin_slsqp constraints=cons, **opts) File "/home/gentai/Enthought/Canopy_64bit/User/lib/python2.7/site-packages/scipy/optimize/slsqp.py", line 360, in _minimize_slsqp fx = func(x) File "/home/gentai/Enthought/Canopy_64bit/User/lib/python2.7/site-packages/scipy/optimize/optimize.py", line 281, in function_wrapper return function(*(wrapper_args + args)) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/opt/scipy_tools.py", line 144, in obj_f obj = project.obj_f(x) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/opt/project.py", line 213, in obj_f return self._eval(konfig, func,dvs) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/opt/project.py", line 182, in _eval vals = design._eval(func,*args) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/eval/design.py", line 142, in _eval vals = eval_func(*inputs) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/eval/design.py", line 240, in obj_f func = su2func(this_obj,config,state) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/eval/functions.py", line 85, in function aerodynamics( config, state ) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/eval/functions.py", line 224, in aerodynamics info = su2run.direct(config) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/run/direct.py", line 81, in direct SU2_CFD(konfig) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/run/interface.py", line 110, in CFD run_command( the_Command ) File "/home/gentai/Workzone/LBF/SU2-master/bin/SU2/run/interface.py", line 268, in run_command raise exception , message SU2.DivergenceFailure: Path = /home/gentai/Workzone/LBF/SU2-master/bin/DESIGNS/DSN_049/DIRECT/, Command = /usr/local/bin/SU2_CFD config_CFD.cfg SU2 process returned error '2' [gentai@node09 bin]$ I even met the same error when I try optimization of tutorial 9. But I don't know why? Does anyone met the same problem? Thank you! |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
[DesignModeler] 2D Airfoil Design Defective Geometry | VSass | ANSYS Meshing & Geometry | 1 | October 9, 2013 11:07 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
Problem with optimal shape design test case--Windows Error 183 | Fang-SIAMM | SU2 Shape Design | 2 | January 28, 2013 15:41 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
