November 18, 2020, 10:46 |
Cells Overlapping Trailing Edge
Rep Power: 10 |
Dear SU2 Developers,
I'm running a continuous shape optimization with the vki turbine present in TestCases/rans/vki_turbine. The problem is I get a wrong deformation at the trailing edge where the cells overlap to each other while on the other part of the airfoil everything looks fine. I'm using Hicks-Henne method to parametrize the airfoil but, even trying different settings, I cannot overtake the problem. Any Idea? Thanks for your work Last edited by FlyBob91; November 19, 2020 at 07:52. |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
[ICEM] Trailing edge meshing problems | juanchope | ANSYS Meshing & Geometry | 2 | June 19, 2014 21:10 |
Y-Plus values at aerofoil leading edge and trailing edge at high incidence | Engr07 | Main CFD Forum | 4 | June 29, 2012 10:42 |
trailing edge problem | Kuo Wei-Jen | Main CFD Forum | 2 | April 14, 1999 10:09 |
