Home > Forums > Software User Forums > SU2 > SU2 Shape Design
FFD set up inside nuzzle
Old   October 20, 2021, 04:21
Default FFD set up inside nuzzle
nadav itz is on a distinguished road
Hello SU2 users,
I'm trying to set up a 3D FFD box for the design of nuzzle intake.
After having a few FFD set-up I noticed that if I place the FFD inside the nuzzle the FFD mapping procedure doesn't work well. This causes the optimization process to end after 1 iteration because SU2_DOT cannot get the gradient and they all equal zero.
When I set the FFD outside the nuzzle, the optimization process work well but the FFD box was far from the surfaces of my model.
I am interested in knowing if the FFD can be set inside the nuzzle. I couldn't find an example for nuzzle intake optimization and I'm not sure why it's happening.
Thanks for the help!
I'm working with SU2 v7.1.1
nadav itz is offline   Reply With Quote
Old   February 7, 2022, 11:12
na
TKatt is on a distinguished road
Maybe take a look at one of the design tutorials of the website: This one https://su2code.github.io/tutorials/Species_Transport/ is kind of a nozzle outlet, so all the relevant FFD features should be applicable similarly. Just dont mind the Species Transport aspects and this maybe could be of help for you.
TKatt is offline   Reply With Quote
ffd, nuzzle, optimization, su2_dot
save to variable filename inside loop FrankR Fluent UDF and Scheme Programming 5 January 30, 2019 11:16
set BC mass-flow-inlet via UDF and via GUI perform different result sawa25 FLUENT 1 February 25, 2015 00:51
correction of Grub after installing Windows XP and 8 immortality Lounge 20 January 5, 2014 17:41
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
