January 31, 2022, 08:29 |
Sensitivity x,y are zeros
Jan Navratil
Rep Power: 9 |
I have still problem with results of sensitivities of drag for example. In surface_adjoint.csv file, the components of sensitivities are 0 in all surface nodes, while Surface sensitivities are non zero values. Same is in the volume adjoint file (adjoint.vtu). Why the SU2 did not calculate projected values? Moreover, if I use deformation kind: DV_KIND= SURFACE_FILE, I'm able to provide surface deformations and then calculated deformed mesh (SU2_DEF). Problem is, that according to notes in config file I should be able to obtain surface sensitivities dJ/dx, dJ/dy by running SU2_DOT with config parameter DV_KIND= SURFACE_FILE. But rutine gives no output file (DV_SENS_FILENAME= surface_sensitivity.dat). I attached text file containing my config. parameters. Does anybody know what might be cause of this struggle? Thank you. Cheers, Jan |
adjoing, sensitivity, su2_dot |
Unhandled variable DPM-dist | mahesh248f1 | FLUENT | 4 | July 15, 2021 10:50 |
Adjoint sensitivity map output doesn't seem right... | nrooy | OpenFOAM | 2 | November 3, 2020 18:58 |
How to implement a sensitivity analysis for certain items | Mason liu | CFX | 10 | August 17, 2017 08:46 |
Estimating lift change using sensitivity | arrow201 | SU2 | 0 | January 31, 2017 13:28 |
What exactly is a sensitivity analysis? | Josh | CFX | 3 | August 19, 2009 09:18 |
