From Ellipse to an Airfoil using Mesh Deformation Code |
April 7, 2023, 02:21 |
Vishnu_iitb
Rep Power: 5 |
Hello Everyone,
I want to get familiar with the Mesh Deformation Code(SU2_DEF). So I plan to take a 2-D ellipse (along with its mesh) and squish it appropriately to naca 0012. To perform this task I plan to parameterize the ellipse geometry using control points from FFD/HH bump function. Then I plan to manually tweak the control points in a sequence of about 20 steps that would eventually lead me to naca 0012 geometry. I know how to parameterize my geometry using SU2 but I do not know how to feed the "manually tweaked control points" to SU2_DEF that can deform the initial mesh. I also want to know after tweaking how can I get the deformed mesh for visualization purpose from SU2_DEF. Any help from the community on this task will be really helpful. Thank You |
April 25, 2023, 10:17 |
Vishnu_iitb
Rep Power: 5 |
Can someone clarify if it is even possible to pass the design variables to SU2_DEF directly through Python? From my understanding of looking into the Shape Optimization.py file and the other optimization tutorials in the website, SU2_DEF suite is somehow invoked under the hood. Can someone share insight on to how is it getting invoked? Thank You |
su2_def |
FFD shape deformation for 3D wing not changing the mesh | lwc24 | SU2 Shape Design | 5 | August 1, 2019 15:17 |
Parameters of a good airfoil mesh | CharlieBra7o | Mesh Generation & Pre-Processing | 4 | November 20, 2018 14:42 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
