Home > Forums > Software User Forums > SU2 > SU2 Shape Design
SU2 NEMO with adjoint method
Old   August 7, 2023, 16:16
Default SU2 NEMO with adjoint method
Apoale is on a distinguished road
Hi everyone,
I am trying to do a 2D shape optimization case in hypersonic regime, using discrete adjoint.
Before to try that I try to know and use successful the adjoint method in SU2 (no NEMO version so without Mutation).
After I used SU2 NEMO with Mutation++, but without adjoint libraries, for hypersonic cases.
Now I am trying to install SU2 with Mutation++ and adjoint libraries together.
After to download the Su2 Code from Github, I run the following command line:
./meson.py build -Denable-cgns=false -Denable-mpp=true -Denable-tecio=true -Denable-autodiff=true -Denable-directdiff=true --prefix=/home/aleapo/SU2_NEMO2/SU2
After copy the 6 lines in my bashrc, I run the following command line:
./ninja -C build install
But I obtain the errors that I show in the images
Do you have any ideas on how I can solve the problem?
I don't find any documentation about SU2 NEMO + adjoint method, is adjoint method implemented in SU2 NEMO?
Thanks you in advance
Apoale is offline   Reply With Quote
Harmonic balance method for calculating multi-stage turbines HIT19B902072 SU2 2 April 24, 2022 01:31
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 05:18
Is SU2 able to handle adjoint for pressure distribution when doing inverse design? Xiaosong SU2 2 December 4, 2016 00:25
Problems launching adjoint max_ SU2 2 March 12, 2016 11:32
Boundary Conditions Of Discrete Adjoint Method For 2D NS Equations Ashkaari Main CFD Forum 4 January 27, 2016 20:05
