Home > Forums > Software User Forums > SU2
MPI Communication within Linear solver
Old   February 21, 2014, 03:59
Default MPI Communication within Linear solver
Dominic Chandar
dominic is on a distinguished road
Send a message via Skype™ to dominic
I would like to know if there are MPI communications within a BCGSTAB iteration ? Seeing through the code, I don't seem to notice that. I can see that all partitions do individual solves and then communicate.
For e.g. in solver_direct_mean.cpp
void CEulerSolver::ImplicitEuler_Iteration(), the Set_MPI_Solution is called at the end, after the solution is computed. May be your convergence would improve if the communication is placed inside the BCGSTAB routine as well ? but many increase your total communication time. - Is this why it was done this way ?
Dominic
dominic is offline   Reply With Quote
Old   March 2, 2014, 19:09
Francisco Palacios
fpalacios is on a distinguished road
Originally Posted by dominic View Post
Dominic
Yep, there is some communication inside de algorithm. In different parts... the most clear ones are when you call the matrix vector multiplication mat_vec(phat, v); or dot product dotProd(r_0, v).
For example the mat_vec is done in
void CSysMatrix::MatrixVectorProduct(const CSysVector & vec, CSysVector & prod, CGeometry *geometry, CConfig *config) {
Cheers,
Francisco
fpalacios is offline   Reply With Quote
Old   March 2, 2014, 23:05
Dominic Chandar
Thank you Francisco, I missed that part ! I can see that there is a
SendReceive_Solution() inside the function you've mentioned.
Linear Solver for Particle Methods prapanj Main CFD Forum 1 December 2, 2013 20:03
please help me which solver is better for my application Ger_US OpenFOAM 8 January 8, 2013 12:29
MPI issues with my own solver davide_c OpenFOAM Running, Solving & CFD 1 March 23, 2012 08:57
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
Getting too many iterations by velocity solving (aborting). Changing U - Solver? suitup OpenFOAM Running, Solving & CFD 0 January 20, 2010 07:45
