June 30, 2014, 17:56 |
Segmentation fault on TNE test case
Dimyriiy Bogdanov
Rep Power: 15 |
Good evening, everyone. I'm getting segmentation fault when running ramc61km simulation from test cases with Argon model and TNE_NAVIER_STOKES solver. I've found that chemistry model for Argon has N2 coefficients, and that's pretty weird. Could you please tell me, how can I implement dummy chemistry model (argon is a non-reacting gas) and run this simulation?
July 19, 2014, 11:25 |
Francisco Palacios
Rep Power: 15 |
The Non-equilibrium solver is on a development stage and the master brach is not updated... if you are interested in this capability you can contact Sean (our expert)
https://adl.stanford.edu/people/copeland.html Cheers, Francisco |
July 21, 2014, 05:59 |
Dimyriiy Bogdanov
Rep Power: 15 |
Thanks! I'll do that!
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Simple test case for k-epilon model | mathletic | Main CFD Forum | 2 | September 28, 2012 03:04 |
segmentation fault when installing OF-2.1.1 on a cluster | Rebecca513 | OpenFOAM Installation | 9 | July 31, 2012 15:06 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 18:46 |
Segmentation Fault moving wing | lr103476 | OpenFOAM Running, Solving & CFD | 5 | May 4, 2006 06:51 |
