Home > Forums > Software User Forums > SU2
Pressure interpolation at Wall (Heat_Flux BC) in SU2
Old   December 3, 2014, 09:22
Smile Pressure interpolation at Wall (Heat_Flux BC) in SU2
Vino
Vino is on a distinguished road
I have used a new weight for calculating derivatives and I am using the new derivatives to reconstruct the variables. I am finding oscillations near wall in pressure plot. I would like to clarify few things to understand whats going wrong.
1) How pressure at the wall is calculated? Is it directly extrapolated from the neighbor? Where is it done in the code? I am unable to find the it in Heat_Flux BC.
2) What should I do if I want to just extrapolate the pressure from interior domain?
3) What should I do If I want to keep the variables at the wall without reconstruction(1st order)?
Thank you very much.!!!
Vino is offline   Reply With Quote
Old   December 14, 2014, 16:39
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by Vino View Post
Thank you for your question.
Since the problem is solved in terms of the conservative variables (density, momentum components, energy) the pressure does not need to be set directly. It is calculated in terms of the conservative variables elsewhere.
To extrapolate terms from the interior, use the normal neighbor. Accessing information from the normal neighbor is done in several places in the code, including BC_HeatFlux_Wall.
hlk is offline   Reply With Quote
Old   December 15, 2014, 00:15
Vino
Thanks for your answer. I forgot to mention that it is for Incompressible(AC). Here pressure is treated as explicit variable (p, u, v). I will try your suggestion. Thanks.
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 11:30
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Radiation interface hinca CFX 15 January 26, 2014 17:11
Pneumatic simulation - moving wall as a function of a pressure difference jbmackay OpenFOAM 0 September 22, 2010 15:51
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 04:05
