Home > Forums > Software User Forums > SU2
Handling higher order reconstruction
Old   November 28, 2014, 04:45
Default Handling higher order reconstruction
Shainath
shainath is on a distinguished road
I am implementing new reconstruction method to get second order results. I have just replaced the LS method of reconstruction with the different one. If I run "viscous flow over cylinder" problem (Re=40) then Cp plot over the cylinder wall shows some oscillations but for LS given by SU2 show no oscillations in a Cp plot.
Am I missing something in this re-implementation, like avoiding reconstruction at the boundary? In general no reconstruction is done at the boundary cells/points. Please give some suggestions. Thank you.
shainath is offline   Reply With Quote
Old   December 14, 2014, 16:24
hlk
Heather Kline
hlk is on a distinguished road
Originally Posted by shainath View Post
Thank you for your question.
One thing you can look into is the use of limiters. These are already used in SU2, so by looking through the code you will be able to find some examples.
I believe for higher order reconstruction you will need more boundary points than currently used by SU2.
If you would like to share your reconstruction method, once you have it working to your satisfaction you can share it on github by forking the SU2 develop branch, adding your modifications, and making a pull request for merging into the develop branch.
hlk is offline   Reply With Quote
higher order discretisation scheme Simon Smokes Main CFD Forum 2 August 23, 2014 07:19
Order of accuracy of reconstruction ganesh Main CFD Forum 7 January 18, 2006 12:00
Higher Order FV Schemes for unstructured meshes Apurva Shukla Main CFD Forum 4 December 15, 2000 09:17
Gradient Estimation for Higher Order Schemes jianxia Main CFD Forum 0 June 6, 2000 19:40
Higher order FVM Sergey Smirnov Main CFD Forum 10 April 15, 2000 01:49
