Home > Forums > Software User Forums > SU2
The edge velocity for CGL
Old   December 17, 2014, 20:38
Default The edge velocity for CGL
Kan
nwpukaka is on a distinguished road
I am now working the moving mesh with SU2, but I found that the GCL term is calculated by averaging the grid velocities at the edge mid-point and dotting with the face normal,
Residual_GCL += 0.5*(GridVel_i[iDim]+GridVel_j[iDim])*Normal[iDim];
I really suspect if the conservation law can be met using averaging velocities? is there any test case showing the conservation law is got met?
Thank you in advance
Jason
nwpukaka is offline   Reply With Quote
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
Radial velocity and tangential velocity on centrifugal fan, johnnyp FLUENT 2 May 24, 2013 07:10
is there any method give node based velocity BC? daniel FLUENT 2 July 18, 2006 21:21
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 05:29
