Home > Forums > Software User Forums > SU2
SU2_SOL error
Old   December 17, 2014, 22:22
Default SU2_SOL error
wangjian
jwang1_09 is on a distinguished road
Hello, everyone.
I compile the SU2 codes in the Windows system, and simulate the ONERAM6 pitching motion. But after the SU2_CFD completes the calculation, it appears that 'C:\SU2\SU2_SOL ended prematurely and may have crashed. exit code 0xc0000005'. The details are in the following document.
Thank you for your help.
jwang1_09 is offline   Reply With Quote
Old   December 23, 2014, 07:54
ericthefatguy's Avatar
Lean ("Eric") Fang
ericthefatguy is on a distinguished road
I did not have the exactly same issue, but I encountered something similar when running SU2 on Windows. Actually, I got "SU2_PRT ended prematurely and may have crashed." at the beginning of the direct case.
Did you complete the direct case in serial or parallel? After reading your txt file, my guess is that your MPI might not be functioning properly.
ericthefatguy is offline   Reply With Quote
Old   December 23, 2014, 08:50
wangjian
Thank you very much. I could simulate some steady situations in parallel without any problems.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
