Home > Forums > Software User Forums > SU2
grid movement - incompressible regime
Old   February 24, 2015, 15:16
Default grid movement - incompressible regime
Suman Chakraborty
suman91 is on a distinguished road
Hi, I was trying to run the NACA 0012 plunging test case that was there by default in the Test-case master folder. I just changed the regime to "INCOMPRESSIBLE" and changed the free stream definition also by giving - density, velocity and viscosity as input. I am getting a "SEGMENTATION FAULT". Is the grid movement not there for incompressible regime? If not can someone tell me where in the source code I need to make changes. I know there is a ROE-TURKEL Pre-conditioning that will allow me to run low mach
number problems using a compressible solver, but I want to use the
incompressible regime only.
Will be looking forward for a reply. Thanks.
suman91 is offline   Reply With Quote
Old   March 5, 2015, 19:33
Francisco Palacios
fpalacios is on a distinguished road
The ALE formulation has not been implemented in the incompressible solver. It is not a terrible task (you just need to mimic the compressible implementation) but it requires some work. Please let us now if you are interested in implementing that capability and create a push request in GitHub.
Best Regards,
Francisco Palacios
SU2 lead developer
fpalacios is offline   Reply With Quote
Old   November 21, 2016, 08:41
Marc Frankenbach
MarcF is on a distinguished road
is this information still up to date for Version 4.3.0? Or is it planned to be implemented in future releases?
Best regards
Marc Frankenbach
MarcF is offline   Reply With Quote
Mesh Conversion : structured to unstructured shreyasr ANSYS 8 April 8, 2019 07:03
Dynamic Mesh resulting in Curved Grid Lines adubois FLUENT 3 April 17, 2014 10:06
About the computation of the gradient of Volume grid node movement Tommy Chen SU2 4 March 12, 2014 16:50
PBC breaks down, is there a grid check tool? gerritgroot SU2 8 June 13, 2013 18:24
Incompressible flow solver (staggered grid) J. Ehrhard Main CFD Forum 1 October 8, 1998 19:47
