March 6, 2015, 14:04 |
Visualize Deformation for Paraview
Rep Power: 11 |
In the latest build of SU2 (v3.2.8) SU2_DEF gives the file surface_grid.dat as the visualization of the deformation. This file is however not readable with Paraview (4.1.0). In earlier releases, the file Surface_Grid.stl was always perfectly readable. Is this a permanent change to the surface_grid file? |
March 9, 2015, 15:49 |
#2 | |
Heather Kline
Rep Power: 13 |
short term, reverting to version 3.2.5 will let you write the paraview files. Long term, I will add this to the github tracker. Last edited by hlk; March 9, 2015 at 16:44. Reason: correction to SU2 version needed |
March 9, 2015, 17:37 |
Heather Kline
Rep Power: 13 |
Correction: I'm not actually sure that version 3.2.5 is the right one. Can you please post which version you were using when it did work?
March 10, 2015, 04:06 |
Rep Power: 11 |
Hi hlk,
thank you for your reply. I was using SU2v3.2.3 when it was still working. I found that I can download previous versions of SU2 at https://github.com/su2code/SU2/releases. Are the previous versions of the test cases also saved somewhere on github? |
March 10, 2015, 09:27 |
#5 | |
Heather Kline
Rep Power: 13 |
The tagged releases of the code and any specific commit of a repository can be checked out by git checkout <string of letters/numbers associated with that commit> from a directory where another version of that repository has been checked out. |
March 11, 2015, 08:07 |
Rep Power: 11 |
Thanks, I got it!
On the GitHub website I browsed in the commits to find the right release and then clicked on "Browse the repository at this point in the history". |
Mesh deformation not converging with 'GRID_DEFORM_METHOD' as "FEA" | diwakaranant | SU2 | 2 | October 11, 2013 15:51 |
Grid deformation for high aspect ratio grids | praveen | SU2 Shape Design | 5 | February 15, 2013 19:50 |
CFX interpolating to a mesh with deformation | martindg | CFX | 5 | October 17, 2012 05:52 |
How to check Zone deformation? | raghu mohan | Fluent UDF and Scheme Programming | 0 | December 22, 2011 01:26 |
Calculation of the deformation rate | titio | OpenFOAM Running, Solving & CFD | 1 | March 22, 2009 08:45 |
