Home > Forums > Software User Forums > SU2
Unexpected increase in computation time for SU2_DOT - SU3.2.8
Old   November 18, 2015, 11:58
Question Unexpected increase in computation time for SU2_DOT - SU3.2.8
Bram Timmer
BramT is on a distinguished road
Dear all,
For my master thesis I'm running an optimization on a conventional wing using multiple FFD boxes:
1: FFD box enveloping the entire wing, used to change the sweep angle.
2: FFD box enveloping the shock wave area on the upper surface of the inboard wing.
3: FFD box enveloping the shock wave area on the lower surface of the outboard wing.
Last night I noticed some discontinuities between the inboard and outboard boxes (at their junction) and decided to change from having two separate boxes to have a single box enveloping the area of the upper surface that I am interested in (also for other reasons). See pictures below for clarity:
The old two boxes (deg_i = 9, deg_j = 19, deg_k = 1, for both):
The new box (deg_i = 19, deg_j = 19, deg_k = 1):
Before the change, running SU2_DOT for 400 variables spread over the two boxes would take 400 seconds (possibly less). After the change, running SU2_DOT for 210 variables takes at least 2100 seconds, if not more.. it's a ridiculous increase of computation time for no apparent reason (you would expect a decrease considering the change in number of variables!).
Does anybody know what causes this increase in computation time and possibly a way to avoid it? Your help will be greatly appreciated!
Regards,
BramT
BramT is offline   Reply With Quote
computation time, su2_dot, su3.2.8
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 10:54
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
