Home > Forums > Software User Forums > SU2
SU2 for multiple sampling optimization
Old   February 16, 2016, 07:38
Question SU2 for multiple sampling optimization
Raj
Raj_1 is on a distinguished road
Recently I started exploring possibility of using SU2 for robust optimization where I need to run the direct and adjoint solver of SU2 at multiple sampling points at each iteration of optimization process and need to feed a modified gradient of the objective to the optimizer.
I guess I need to write few scripts to do it. If so, it would be great if someone can provide me some ideas to implement it as:
1. How can I call SU2_CFD multiple times for each iteration of the optimization process.
2. How to modify objective gradient wrt design var. in the iteration process.
Thanks
Raj
Raj_1 is offline   Reply With Quote
Old   February 19, 2016, 01:52
Francisco Palacios
fpalacios is on a distinguished road
Hi Raj,
What you are proposing is a deep modification of the optimization algorithm. There are different ways to proceed and, obviously, the first step is to be familiar with the python part of the code. I think it would be interesting if you take a look at SU2_PY/SU2/opt/scipy_tools.py and SU2_PY/compute_polar.py
The first file is the highest level to define an optimization strategy... in this case SLSQP using Scipy. The second file is just an example of how to run a polar.
Best,
Francisco Palacios
fpalacios is offline   Reply With Quote
Old   February 22, 2016, 09:43
Raj
Dear Francisco,
Thank you very much for you kind suggestions. I will try all possibilities.
Regards,
Dinesh
Old   August 6, 2016, 14:16
Default Multi-point optimization
Eran Arad
Arad is on a distinguished road
Hi Raj,
I find your question very intersting and important. Especially if one looks at multi-points
optimization and and an objective function/restraints that are evaluated at different flow conditions. Would you like to share your experience in this field ?
Best regards,
Eran
Arad is offline   Reply With Quote
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 16:17
Error in shape optimization SU2 v3.2.8 Fedey90 SU2 4 February 7, 2016 10:34
SU2 Shape optimization questions AdriC SU2 Shape Design 6 January 27, 2016 04:25
Question about SU2 optimization YoniHe SU2 Shape Design 3 January 15, 2016 00:31
SU2 shape optimization initialization method? gina07 SU2 Shape Design 1 May 2, 2015 16:40
