Home > Forums > Software User Forums > SU2
Need help for my first case
Old   May 4, 2016, 05:33
Default Need help for my first case
nicolas
nicodsi78 is on a distinguished road
First, thank you to all the contributors of SU2 and this forum!
I would like to have your feedback concerning my study : I need to impose a non-uniform field of temperature on an airfoil (this is in a 2D computation).
In my mind, the best option would be to have the possibility to define this boundary condition in specifying a file (for example) in which the temperature is written for each point of the airfoil boundary.
If I’m not mistaken, this feature does not exist natively in SU2.
Thus, I have discretized my airfoil shape into n small segments Ln that I have defined as markers in the mesh file.
In the configuration file I get this :
% Navier-Stokes (no-slip), isothermal wall marker(s) (NONE = no marker)
% Format: ( marker name, constant wall temperature (K), ... )
MARKER_ISOTHERMAL= ( L1, T1,....... Ln, Tn )
% Farfield boundary marker(s) (NONE = no marker)
MARKER_FAR= ( farfield )
% Marker(s) of the surface to be plotted or designed
MARKER_PLOTTING= ( L1,......Ln)
% Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated
MARKER_MONITORING= ( L1,.......Ln)
For the moment this is not working, the computation stops with the following error message :
"85331, 0.0017285331, 0.0017285331, 0.0017285331, 0.001728533:24068 terminated with signal 11 at PC=3d5867e50e SP=7fff6dfd05d8. Backtrace: segmentation fault"
Do you think the way I’m managing this boundary condition is correct?
Thank you in advance,
Regards,
nicodsi78 is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 10:13
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Transient case running with a super computer microfin FLUENT 0 March 31, 2009 11:20
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
