Home > Forums > Software User Forums > SU2
Stop SU2 during a run
Old   May 25, 2016, 08:15
Default Stop SU2 during a run
Eran Arad
Arad is on a distinguished road
In a parallel SU2 run (using parallel_computation.py) on many compute nodes:
Is there a way to stop the run in a peaceful manner (that is, not ctrl C but in a way that
all output and restart files are collected and written down before exit).
Common practices are sending a kill command with parameters to one of the compute nodes, or touching a file with a pre-coded name (like killSU2) in the running folder, that once located, initiate ordered run termination.
Could not trace any structure of that kind in the source. Did I miss something ?
Thanks
Eran
Arad is offline   Reply With Quote
Old   May 30, 2016, 07:19
Tim Albring
talbring is on a distinguished road
Hi Arad,
you can create a file "runtime.dat" in the working folder to set the new number of external iterations (so just one line "EXT_ITER=...").
talbring is offline   Reply With Quote
Old   August 1, 2016, 11:32
Default Partial solution
Eran Arad
Hi Talbring
Your suggestion worked nicely for direct solution.
However, in optimization run, using shape_optimization.py script,
the runtime.dat file had no effect. i have set there
FFD_ITERATIONS, FFD_TOLERANCE and EXT_ITER
but none was read or had an effect on the
running job. Is there other way to control an optimization run ?
Thanks
Old   August 4, 2016, 02:48
jit
jitendraseregar@gmail.com is on a distinguished road
Originally Posted by talbring View Post
Hi Arad,
I have similar situation, where I have to stop CFD solver at particular iteration and import new surface gird file and continue running CFD solver with new file
jitendraseregar@gmail.com is offline   Reply With Quote
Old   October 15, 2016, 02:36
Martin Simon
martinsimon is on a distinguished road
Did anyone get the solution for the mp optim run?
martinsimon is offline   Reply With Quote
Old   March 7, 2017, 06:38
beatlejuice is on a distinguished road
Hey Arad,
if you put the runtime.dat file into the folders :
DESIGNS/0.../DIRECT/
or
DESIGNS/0.../ADJOINT/
it should work ... at least EXT_ITER= ... works to finish the direct or the adjoint computation ... but it will proceed the optimization procedure ....
cheers
beatlejuice is offline   Reply With Quote
run-time, terminate
stop when I run in parallel Nolwenn OpenFOAM 36 March 21, 2021 04:56
How to run SU2 on cluster of computers (How to specify nodes ?) aero_amit SU2 29 February 24, 2020 13:44
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Some questions about a multi region case run in parallel zfaraday OpenFOAM Running, Solving & CFD 5 February 23, 2017 10:25
Transient run continues from last time (when startover is desired) bongbang CFX 2 March 22, 2015 23:05
