June 4, 2016, 09:03 |
F16 Optimization
Tom
Rep Power: 10 |
Hi everyone
I have two questions , it would be great if one can help when we run SU2_DEF for ffd setting two extra files are crated named "surface_grid.dat" and "volumetric_grid.dat" . can some one says what are does files? and also regarding F16 optimization I solved the flow and adjoint equations on the geometry, they both converged to -13. but when I see the Surface_Sensitivity contour the numbers are as in the Pic I attached , why are they so hight ? and also, how can I see the deformation of FFD box during shpe optimization? thanks alot |
June 12, 2016, 19:25 |
#2 | |
Heather Kline
Rep Power: 13 |
Two of these conveniently have the same answer: to view the deformation of the surface and grid, view the surface_grid.dat and/or volumetric_grid.dat files. These files contain the original and deformed meshes for the surface and volume. The surface grid contains the mesh only on the marker in MARKER_DESIGNING, which is often easier to visualize for being a smaller file and only the surface being deformed. The volume file can be useful for investigating deformed mesh quality. You will also see an ffd_boxes.dat file, which contains the ffd box control points and their deformed locations. In terms of the high values, these can occur sometimes near sharp edges and/or where there is a locally high residual although the majority of the solution is well converged. You can readjust the scale of your plot to view the variation over the rest of the geometry, and if inaccuracy near sharp edges is causing problems for gradient calculations, you can use the sharp edge removal, which will identify sharp edges (note that REF_SHARP_EDGES may need to be modified to identify the sharp edges), and neglect the sensitivities near them (where SHARP_EDGE_COEFF controls how far from the sharp edge to neglect). Higher mesh resolution near sharp edges may also help. |
Parameters rhoSimpleFoam | marcus85 | OpenFOAM Pre-Processing | 0 | May 15, 2013 09:36 |
Cad Model - Design parameters - Parts and Regions | crevoise | STAR-CCM+ | 1 | January 29, 2013 07:52 |
Parameters for multigrid solver | HaZe | OpenFOAM Running, Solving & CFD | 3 | January 28, 2012 02:05 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
