All zeros: Skin Friction Coefficient, Heat Flux, Y Plus |
May 24, 2016, 01:38 |
Data C
Rep Power: 10 |
I run one of the the SU2 Edu example airfoils: airfoil_naca4412_selig.dat, default configuration, and RANS.
After a successful run, I open the flow.vtk and find the scalars Skin_Friction_Coefficient, Heat_Flux, and Y_Plus have the first value as non-zero and the rest of them are zeros. Is that normal? All other scalars seem to be correct. Thanks. |
June 18, 2016, 11:12 |
#2 | |
Heather Kline
Rep Power: 13 |
There was an issue with the paraview format recently which was fixed, so the most recent release may help. However, this could also be due to the surface marker: if you set the boundary as MARKER_EULER, it will be a slip wall which will have zero skin friction. For a no-slip wall the boundary condition should be heatflux (with heatflux set at 0 for adiabatic) or isothermal. |
heat flux, skin friction coefficient, su2 edu, y plus |
Skin Friction Coefficient | FrenchyTim | FLUENT | 10 | January 15, 2018 10:41 |
Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 11:45 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
User wall heat flux coefficient specification | crevoise | STAR-CCM+ | 0 | January 15, 2014 08:26 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
