August 17, 2016, 05:09 |
Invalid option name
Suraj Sanka
Rep Power: 9 |
Hi everyone,
I am using SU2-4.2.0 version and I am getting the following invalid option error when I try to run Onera M6 test case as suggested in the test guides in su2 github page. OPT_BOUND_UPPER: Invalid Option name. Check current SU2 options in config_template.cfg OPT_BOUND_LOWER: Invalid Option name. Check current SU2 options in config_template.cfg However the option names are the same in the config_template.cfg file. Can anyone help me with this problem Thank you in advance, Suraj. |
August 17, 2016, 14:51 |
#2 | |
Heather Kline
Rep Power: 13 |
First, check that these options only exist once in the config file, if they are listed more than once that will cause a problem. Second, check that you are not using an older installation. This option changed name and format a while back, and if you have previously installed an older version you may still have the executable somewhere - to troubleshoot, check the output of 'which SU2_CFD', check your PATH variables, make sure that you ran 'make install' and not just 'make' (which would compile the code but not place the final executables in the specified bin/), and/or remove old versions. |
August 19, 2016, 06:31 |
#3 | |
Suraj Sanka
Rep Power: 9 |
The options mentioned are used only once in the configuration file. I have checked to see if there are any older versions of Su2 installed, there aren't any. However while installing su2 I first installed it without any prefix and then specified a prefix path and installed again by make and make install commands and then copied the necessary variables in to the bash file. But when I check output of which SU2_CFD it is showing /usr/local/bin/SU2 which is not the prefix path I gave the second time. I tried uninstalling and installing again but it is only removing the 2nd installed version (which is also 4.2.0) |
invalid option name, opt_bound_lower, opt_bound_upper |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
particle tracking | sakurabogoda | CFX | 7 | December 4, 2013 23:12 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
