Home > Forums > Software User Forums > SU2
May I know the command used for running FSI serial&parallel
Old   September 23, 2016, 08:20
Default May I know the command used for running FSI serial&parallel
shiva
shivak is on a distinguished road
Dear Sir/Madam
May I know the command used for running FSI serial & FSI parallel
I am trying to solve a standard test case and mesh is in .su2 format
Thanks
Siva kumar
shivak is offline   Reply With Quote
Old   October 4, 2016, 05:48
Giulio
LaSerpe is on a distinguished road
You may need to use the python script parallel_computation_fsi.py -f "name_of_config.cfg" -n "Nproc"
You may also want to try mpirun -n "Nproc" SU2_CFD "name_of_config.cfg", if it doesn't work try using both mpirun.mpich or mpirun.openmpi cause it may happen that both libraries are installed on your machine and you'll need to specify the one you used to compile the binaries.
Remember that after SU2_CFD computation finishes you'll need to reconstruct the solution by executing SU2_SOL
Giulio Gori
Phd candidate, Politecnico di Milano
LaSerpe is offline   Reply With Quote
Old   October 17, 2016, 05:51
shiva
Thanks for your reply. I din't understand...can you please brief how to reconstruct the solution by executing SU2_SOL after finishing SU2_CFD computation for FSI application..
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 04:14
initial file for fsi modeling? mortazavi CFX 0 July 21, 2009 02:06
fsi sun Siemens 8 January 19, 2009 23:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
Could you suggest some Useful FSI textbook? BI CHANG CFX 0 January 14, 2006 14:31
