Home > Forums > Software User Forums > SU2
Unable to run in parallel
Old   April 4, 2017, 02:14
Default Unable to run in parallel
Boris Mandadz
bmandadz is on a distinguished road
I am trying to get up and running with SU2 but cannot seem to get the python scripts to run. Trying to run the turbulent ONERAM6 case:
$parallel_computation.py -n 4 -f turb_ONERAM6.cfg
I get this:
Traceback (most recent call last):
File "/usr/local/bin/parallel_computation.py", line 36, in <module>
sys.path.append(os.environ['SU2_RUN'])
File "/usr/lib/python2.7/UserDict.py", line 40, in __getitem__
raise KeyError(key)
KeyError: 'SU2_RUN'
Any help will be appreciated!
bmandadz is offline   Reply With Quote
Old   April 4, 2017, 05:19
Tim Albring
talbring is on a distinguished road
Hi Boris,
make sure that the environment variable SU2_RUN points to the correct folder.
Have a look here for more information:
https://github.com/su2code/SU2/wiki/...rallel-support
Tim
talbring is offline   Reply With Quote
Old   April 4, 2017, 12:13
Boris Mandadz
I am using the suggested modifications to the bashrc file after installation. I used the following modifications to the config file:
./configure CXXFLAGS="-O3" --enable-mpi
--with-cc=/usr/bin/mpicc --with-cxx=/usr/bin/mpicxx
--with-CGNS-lib=/usr/local/lib --with-CGNS-include=/usr/local/include --enable-PY_WRAPPER
and then include the following lines in the bshrc file:
export SU2_RUN="/usr/local/bin"
export SU2_HOME="/home/boris/SU2"
export PATH=$PATH:$SU2_RUN
export PYTHONPATH=$PYTHONPATH:$SU2_RUN
I also tried:
export SU2_RUN="/usr/bin"
Actually no matter what I do to the paths I get the same error.
Old   April 4, 2017, 16:14
Boris Mandadz
The issue is resolved. Using the following in the bashrc file:
export SU2_RUN="/usr/local/lib"
and making sure MPICH is properly installed.
Thank you!
Old   July 19, 2017, 07:33
jared
jsagaga is on a distinguished road
Thank you!
Hello Boris, were you running su2 on windows or linux? I'm trying to run in parallel as well (windows 10 via command prompt), but have been unsuccessful.
jsagaga is offline   Reply With Quote
Old   July 19, 2017, 09:28
Boris Mandadz
I am running Windows Server 2012 R2 with Ubuntu 16 on Virtualbox. I think after installing many packages the one the fixed the situation was the actual mpich -> $sudo apt get install mpich.
I also used this guide:
https://askubuntu.com/questions/6897...buntu-14-04lts
Good luck!
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 Yesterday 07:56
unable to run in parallel with OpenFOAM 2.2 on CentOS einatlev OpenFOAM Running, Solving & CFD 9 June 26, 2014 00:24
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
