April 4, 2017, 02:14 |
Unable to run in parallel
Boris Mandadz
Rep Power: 12 |
I am trying to get up and running with SU2 but cannot seem to get the python scripts to run. Trying to run the turbulent ONERAM6 case:
$parallel_computation.py -n 4 -f turb_ONERAM6.cfg I get this: Traceback (most recent call last): File "/usr/local/bin/parallel_computation.py", line 36, in <module> sys.path.append(os.environ['SU2_RUN']) File "/usr/lib/python2.7/UserDict.py", line 40, in __getitem__ raise KeyError(key) KeyError: 'SU2_RUN' Any help will be appreciated! |
April 4, 2017, 05:19 |
Tim Albring
Rep Power: 10 |
Hi Boris,
make sure that the environment variable SU2_RUN points to the correct folder. Have a look here for more information: https://github.com/su2code/SU2/wiki/...rallel-support Tim |
April 4, 2017, 12:13 |
Boris Mandadz
Rep Power: 12 |
I am using the suggested modifications to the bashrc file after installation. I used the following modifications to the config file:
./configure CXXFLAGS="-O3" --enable-mpi --with-cc=/usr/bin/mpicc --with-cxx=/usr/bin/mpicxx --with-CGNS-lib=/usr/local/lib --with-CGNS-include=/usr/local/include --enable-PY_WRAPPER and then include the following lines in the bshrc file: export SU2_RUN="/usr/local/bin" export SU2_HOME="/home/boris/SU2" export PATH=$PATH:$SU2_RUN export PYTHONPATH=$PYTHONPATH:$SU2_RUN I also tried: export SU2_RUN="/usr/bin" export SU2_HOME="/home/boris/SU2" export PATH=$PATH:$SU2_RUN export PYTHONPATH=$PYTHONPATH:$SU2_RUN Actually no matter what I do to the paths I get the same error. |
April 4, 2017, 16:14 |
Boris Mandadz
Rep Power: 12 |
The issue is resolved. Using the following in the bashrc file:
export SU2_RUN="/usr/local/lib" export SU2_HOME="/home/boris/SU2" export PATH=$PATH:$SU2_RUN export PYTHONPATH=$PYTHONPATH:$SU2_RUN and making sure MPICH is properly installed. Thank you! |
July 19, 2017, 07:33 |
jared
Rep Power: 11 |
Hello Boris, were you running su2 on windows or linux? I'm trying to run in parallel as well (windows 10 via command prompt), but have been unsuccessful.
July 19, 2017, 09:28 |
#6 | |
Boris Mandadz
Rep Power: 12 |
I also used this guide: https://askubuntu.com/questions/6897...buntu-14-04lts Good luck! |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
unable to run in parallel with OpenFOAM 2.2 on CentOS | einatlev | OpenFOAM Running, Solving & CFD | 9 | June 26, 2014 00:24 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
