Wing twist optimization using mesh deformation |
November 4, 2017, 22:37 |
WANG,Hao
Rep Power: 9 |
Hi everyone,
I would like to optimize the twist distribution of a rectangular wing in SU2. The cross sectional shape must remain the same. Does anyone know how I could do this using mesh deformation? FFD_TWIST seems suitable for this purpose, but I can't get that to work properly. Here is the definition of FFD_TWIST: ( 19, Scale | Mark. List | FFD_BoxTag, j_Ind, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End ) Could anyone explain the meaing of the parameters listed above? Thank you in advance! To be more clear, I give my definations for my FFD setting: Code:
FFD_TOLERANCE= 1E-10 FFD_ITERATIONS= 500 FFD_DEFINITION= (WING,-0.0603, -0.03, -0.04836,0.785,-0.03, -0.04836,1.14,1.23, -0.04836,0.6851,1.23, -0.04836,-0.0603,-0.03, 0.04836,0.785,-0.03, 0.04836,1.14,1.23, 0.04836,0.6851,1.23, 0.04836) FFD_DEGREE= (4, 3, 1) FFD_CONTINUITY= NO_DERIVATIVE DV_KIND= FFD_TWIST DV_PARAM= ( WING, 1, 1,1,1, 1, 1, 1) DV_VALUE= 3 DEFINITION_DV= ( 19, 1.0 | UPPER_SIDE, LOWER_SIDE, TIP | WING, 1, 1,1,1, 1, 1, 1 ) |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
