January 15, 2018, 07:52 |
Viscous Time Step Calculation
C. Atkins
Rep Power: 9 |
I have a query regarding the time step calculation in viscous simulations. The CNSSolver::SetTime_Step routine adds together the lambda for viscosity and the lambda for thermal conductivity. I was under the impression that one should take the maximum of those to determine the timestep - but I could well be wrong? I have tried to find a definitive answer and couldn't, so would someone be able to give me a reference/explanation as to why the timestep is calculated in this way? Thanks, Chay |
February 24, 2018, 12:57 |
Francisco Palacios
Rep Power: 15 |
Like a lot of stuff in these software the reason is test and error, historical reasons and a conservative solution. If I were you I would try you proposal and if it better just create a pull request. By the way if you are a developers check out the SU2 IDS www.su2devsociety.org
Best, Francisco |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 41 | August 23, 2023 02:48 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
