Home > Forums > Software User Forums > SU2
How to initialize the shock tube problem by modifying the restart file
Old   April 3, 2018, 20:59
Default How to initialize the shock tube problem by modifying the restart file
hust
zjqzjs is on a distinguished road
Hi SU2ers,
I would like to simulate shock tube problem, for which I need to set two different initial conditions.I have tried the comments and advice of the following links to set "SetInitialCondition" class and it can work.However, It cannot be directly used for unsteady simulation.So I tried another method suggested, set up a restart file that has the initial conditions you want.But when I restart from the solution_flow_00000.dat and solution_flow_00001.dat after one time step, the density field looks normal and the pressure field becomes very uniform.Btw, the version I used is SU2 v6.0.0.
Initialization with two different initial states-Shock tube problem.!!!
The initialization of flow field for time accurate, unsteady simulation and BC
I don't know how to eliminate this error. Any help would be appreciate, thanks!
Best
zjqzjs is offline   Reply With Quote
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
