Home > Forums > Software User Forums > SU2
Loading Structured CGNS Mesh
Old   June 7, 2018, 17:32
Default Loading Structured CGNS Mesh
Neo63 is on a distinguished road
Hi guys,
New SU2 user here. I have an O-grid for an airfoil, which has been extruded in the z dimension for 1 cell height. When I load it into SU2 the following appears:
---------------------- Read Grid File Information -----------------------
Reading the CGNS file: airfoil.cgns.
CGNS file contains 1 database(s).
Database 1, BASE#1: 1 zone(s), cell dimension of 3, physical dimension of 3.
Zone 1, domain.00001: 251 vertices, 2 cells, 129 boundary vertices.
Reading grid coordinates.
Number of coordinate dimensions is 3.
Loading CoordinateX values.
Invalid range of data requested
I suspect it's due to the CGNS file being structured, as I've had the same issue loading the structured grids here but the unstructured CGNS grids load fine. Has anyone encountered this before? Is there a way to load it directly into SU2, or convert the file to unstructured format?
Thanks in advance.
Neo63 is offline   Reply With Quote
Old   June 18, 2018, 14:18
Ahmed MKAOUAR
Ahmed mkaouar is on a distinguished road
Hello
i'm having the same problème here
Did you find a solution please let me know how
Thank you
Ahmed mkaouar is offline   Reply With Quote
cgns
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Volume mesh for Cyclone separator Rajan Pointwise & Gridgen 17 May 4, 2014 05:38
[ICEM] ICEM Structured Mesh Problem OMJT ANSYS Meshing & Geometry 3 March 22, 2013 10:06
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
