Home > Forums > Software User Forums > SU2
Heat Transfer output?
Old   December 20, 2018, 09:48
Default Heat Transfer output?
Tom Jentink
jentink is on a distinguished road
I need to have surface heat transfer in my output files. Does SU2 do this?
Thanks.
jentink is offline   Reply With Quote
Old   December 21, 2018, 14:04
Amit
aero_amit is on a distinguished road
It writes surface heat flux for ISOTHERMAL wall (where u r setting cold wall temperature) cases.
aero_amit is offline   Reply With Quote
Old   December 21, 2018, 14:27
Tom Jentink
I was sure it did also... what is the variable called? I see the 3 Cf components and then 'h'.
Old   December 25, 2018, 14:45
Amit
In ParaView output it's named as Heat_Flux and in Tecplot output it's called h.
Also in ParaView output it gives Skin friction Coefficient while in Tecplot output it writes all cf components.
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 06:43
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Particle Tracking - Heat transfer and temperature mxodio CFX 8 August 7, 2015 13:43
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
