Home > Forums > Software User Forums > SU2
High drag coefficent
Old   March 12, 2019, 10:14
Default High drag coefficent
A Pedrioli
andreape is on a distinguished road
Hi guys!
I'm performing some simulations in SU2 of some multi-element airfoils at ~10^6 Reynolds number. Unfortunately i'm not able to capture correctly the drag coefficent (it's 2/3 times bigger than the experimental data) , while the lift coefficent agree more or less quite good.
Here the configuration file:
PHP Code:
SU2 configuration file                                                       %
DateOct 10th2016                                                         %
File Version 6.1.0 "Falcon"                                                %
DIRECTADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
Physical governing equations (EULERNAVIER_STOKES,
WAVE_EQUATIONHEAT_EQUATIONLINEAR_ELASTICITY,
POISSON_EQUATION)
PHYSICAL_PROBLEMNAVIER_STOKES
Specify turbulent model (NONESASA_NEGSST)
KIND_TURB_MODELSA
Specify transition model (NONELMBC)
KIND_TRANS_MODELBC
FREESTREAM_TURBULENCEINTENSITY
0.1
Mathematical problem (DIRECTCONTINUOUS_ADJOINT)
MATH_PROBLEMDIRECT
Regime type (COMPRESSIBLEINCOMPRESSIBLEFREESURFACE)
REGIME_TYPEINCOMPRESSIBLE
Restart solution (NOYES)
RESTART_SOLNO
% -------------------- INCOMPRESSIBLE FREE-STREAM DEFINITION ------------------%
Free-stream density (1.2886 Kg/m^(air), 998.2 Kg/m^(water))
FREESTREAM_DENSITY1.2
Free-stream velocity (m/s)
FREESTREAM_VELOCITY= ( 14.54402664808851.536851931609040.00 )
Free-stream viscosity (1.853E-5 Ns/m^(air), 0.798E-3 Ns/m^(water))
FREESTREAM_VISCOSITY1.8e-05
REF_DIMENSIONALIZATION
DIMENSIONAL
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
Reference origin for moment computation
REF_ORIGIN_MOMENT_X
0.25
REF_ORIGIN_MOMENT_Y
0.00
REF_ORIGIN_MOMENT_Z
0.00
Reference length for pitchingrolling, and yawing non-dimensional moment
REF_LENGTH
1.0
Reference area for force coefficients (0 implies automatic calculation)
REF_AREA1.0
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
Navier-Stokes wall boundary marker(s) (NONE no marker)
MARKER_HEATFLUX= ( airfoil0.0)
Farfield boundary marker(s) (NONE no marker)
MARKER_FAR= ( farfield )
Marker(sof the surface to be plotted or designed
MARKER_PLOTTING
= ( airfoil)
Marker(sof the surface where the functional (CdCletc.) will be evaluated
MARKER_MONITORING
= ( airfoil)
COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
Numerical method for spatial gradients (GREEN_GAUSSWEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRADWEIGHTED_LEAST_SQUARES
Courant-Friedrichs-Lewy condition of the finest grid
CFL_NUMBER
100.0
Adaptive CFL number (NOYES)
CFL_ADAPTNO
Parameters of the adaptive CFL number (factor downfactor upCFL min value,
CFL max value )
CFL_ADAPT_PARAM= ( 1.50.51.0100.0 )
Number of total iterations
EXT_ITER
1000000
% ----------------------- SLOPE LIMITER DEFINITION ----------------------------%
Coefficient for the limiter
VENKAT_LIMITER_COEFF
0.01
Coefficient for the sharp edges limiter
ADJ_SHARP_LIMITER_COEFF
3.0
Reference coefficient (sensitivity) for detecting sharp edges.
REF_SHARP_EDGES3.0
Remove sharp edges from the sensitivity evaluation (NOYES)
SENS_REMOVE_SHARPNO
% ------------------------ LINEAR SOLVER DEFINITION ---------------------------%
Linear solver for implicit formulations (BCGSTABFGMRES)
LINEAR_SOLVERFGMRES
Preconditioner of the Krylov linear solver (JACOBILINELETLU_SGS)
LINEAR_SOLVER_PRECLU_SGS
Minimum error of the linear solver for implicit formulations
LINEAR_SOLVER_ERROR
1E-4
Max number of iterations of the linear solver for the implicit formulation
LINEAR_SOLVER_ITER
5
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
Multi-Grid Levels (no multi-grid)
MGLEVEL0
Multi-grid cycle (V_CYCLEW_CYCLEFULLMG_CYCLE)
MGCYCLEV_CYCLE
Multi-grid pre-smoothing level
MG_PRE_SMOOTH
= ( 123)
Multi-grid post-smoothing level
MG_POST_SMOOTH
= ( 000)
Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH
= ( 000)
Damping factor for the residual restriction
MG_DAMP_RESTRICTION
0.75
Damping factor for the correction prolongation
MG_DAMP_PROLONGATION
0.75
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
Convective numerical method (JSTLAX-FRIEDRICHCUSPROEAUSMHLLC,
TURKEL_PRECMSW)
CONV_NUM_METHOD_FLOWROE
Monotonic Upwind Scheme for Conservation Laws (TVDin the flow equations.
Required for 2nd order upwind schemes (NOYES)
MUSCL_FLOWYES
Slope limiter (VENKATAKRISHNANMINMOD)
SLOPE_LIMITER_FLOWVENKATAKRISHNAN
2nd and 4th order artificial dissipation coefficients
JST_SENSOR_COEFF
= ( 0.50.02 )
Time discretization (RUNGE-KUTTA_EXPLICITEULER_IMPLICITEULER_EXPLICIT)
TIME_DISCRE_FLOWEULER_IMPLICIT
RELAXATION_FACTOR_FLOW
0.8
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
Convective numerical method (SCALAR_UPWIND)
CONV_NUM_METHOD_TURBSCALAR_UPWIND
Monotonic Upwind Scheme for Conservation Laws (TVDin the turbulence equations.
MUSCL_TURBYES
SLOPE_LIMITER_TURBVENKATAKRISHNAN
Time discretization (EULER_IMPLICIT)
TIME_DISCRE_TURBEULER_IMPLICIT
Reduction factor of the CFL coefficient in the turbulence problem
CFL_REDUCTION_TURB
1.0
Relaxation coefficient
RELAXATION_FACTOR_TURB
0.95
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
Convergence criteria (CAUCHYRESIDUAL)
CONV_CRITERIARESIDUAL
Residual reduction (order of magnitude with respect to the initial value)
RESIDUAL_REDUCTION10
Min value of the residual (log10 of the residual)
RESIDUAL_MINVAL= -20
Start convergence criteria at iteration number
STARTCONV_ITER
10
Number of elements to apply the criteria
CAUCHY_ELEMS
100
Epsilon to control the series convergence
CAUCHY_EPS
1E-6
% Function
to apply the criteria (LIFTDRAGNEARFIELD_PRESSSENS_GEOMETRY
SENS_MACHDELTA_LIFTDELTA_DRAG)
CAUCHY_FUNC_FLOWDRAG
% ------------------------- GRID ADAPTATION STRATEGY --------------------------%
Kind of grid adaptation (NONEPERIODICFULLFULL_FLOWGRAD_FLOW,
FULL_ADJOINTGRAD_ADJOINTGRAD_FLOW_ADJROBUST,
FULL_LINEARCOMPUTABLECOMPUTABLE_ROBUST,
REMAININGWAKESMOOTHINGSUPERSONIC_SHOCK)
KIND_ADAPTFULL_FLOW
Percentage of new elements (% of the original number of elements)
NEW_ELEMS5
Scale factor for the dual volume
%DUALVOL_POWER0.5
Adapt the boundary elements (NOYES)
ADAPT_BOUNDARYYES
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
Mesh input file
MESH_FILENAME
my-mesh.su2
Mesh input file format (SU2CGNSNETCDF_ASCII)
MESH_FORMATSU2
Mesh output file
MESH_OUT_FILENAME
mesh_out.su2
Restart flow input file
SOLUTION_FLOW_FILENAME
solution_flow.dat
Restart adjoint input file
SOLUTION_ADJ_FILENAME
solution_adj.dat
Output file format (PARAVIEWTECPLOTSTL)
OUTPUT_FORMATPARAVIEW
Output file convergence history (w/o extension
CONV_FILENAMEhistory
Output file restart flow
RESTART_FLOW_FILENAME
restart_flow.dat
Output file restart adjoint
RESTART_ADJ_FILENAME
restart_adj.dat
Output file flow (w/o extensionvariables
VOLUME_FLOW_FILENAME
flow
Output file adjoint (w/o extensionvariables
VOLUME_ADJ_FILENAME
adjoint
Output objective function gradient (using continuous adjoint)
GRAD_OBJFUNC_FILENAMEof_grad.dat
Output file surface flow coefficient (w/o extension)
SURFACE_FLOW_FILENAMEsurface_flow
Output file surface adjoint coefficient (w/o extension)
SURFACE_ADJ_FILENAMEsurface_adjoint
Writing solution file frequency
WRT_SOL_FREQ
250
Writing convergence history frequency
WRT_CON_FREQ
I checked also the y+ and it is around 1 (first cell height = 1e-5).
Regarding the mesh:
- Skewness below 0.7
- Max aspect ratio in the boundary layer ~200
- (chord length)/(environment length) = 1/100 (blockage ratio?)
Any idea to improve my model??
Thank you!
PS: I wanted to try the LM transition model with SST turbulence model but I had some problems...is it actually working??
andreape is offline   Reply With Quote
Naca airfoil with too high drag andimb OpenFOAM Running, Solving & CFD 43 March 26, 2021 14:33
Modified the motorBike tutorial, getting very high drag ben1793 OpenFOAM Running, Solving & CFD 4 August 16, 2013 03:25
coefficient of drag too high samneos Phoenics 0 February 19, 2013 15:33
Drag Coeffient monitor very high dwilson STAR-CCM+ 2 December 21, 2012 05:56
Coefficent of Drag jd210 OpenFOAM Running, Solving & CFD 0 March 8, 2011 20:34
