Home > Forums > Software User Forums > SU2
Customized inlet profile for Turbomachinery (MARKER_GILES)
Prev Previous Post   Next Post Next
Old   July 21, 2019, 18:14
Default Customized inlet profile for Turbomachinery (MARKER_GILES)
Aman uz zaman Baig
aman_baig is on a distinguished road
I know we can define a customized inlet profile using
SPECIFIED_INLET_PROFILE = YES,
and that would work as an alternative to,
MARKER_INLET = ().
But for TurboMachinery applications, we have MARKER_GILES, such that:
MARKER_GILES= (inflow, TOTAL_CONDITIONS_PT, 169623.33, 305.76,, 1.0, 0.0, 0.0,1.0,1.0, outmix, MIXING_OUT, 0.0, 0.0, 0.0, 0.0, 0.0,1.0,1.0, inmix, MIXING_IN, 0.0, 0.0, 0.0, 0.0, 0.0,1.0, 1.0 outflow, STATIC_PRESSURE, 99741.00, 0.0, 0.0, 0.0, 0.0,1.0,1.0)
In this case, if I use SPECIFIED_INLET_PROFILE = YES then it will output a sample inlet_example.dat file with NMARK = 0. So I tried this out:
MARKER_INLET=(inflow, 305.76, 169623.33,, 1.0, 0.0, 0.0)
MARKER_GILES= (outmix, MIXING_OUT, 0.0, 0.0, 0.0, 0.0, 0.0,1.0,1.0, inmix, MIXING_IN, 0.0, 0.0, 0.0, 0.0, 0.0,1.0, 1.0 outflow, STATIC_PRESSURE, 99741.00, 0.0, 0.0, 0.0, 0.0,1.0,1.0)
This does output a valid inlet_example.dat file but that is not read by SU2 when I give that name in INLET_FILENAME. I don't know how to resolve it.
If someone can suggest something that would be helpful. I want to accommodate a distortion in the inlet profile.
Mesh for the attached config file: https://github.com/su2code/TestCases...l_stage_2D.su2
EDIT:
Surprisingly the same configuration works for a single row case. This must be a SU2 bug.
Single row (mesh):
https://github.com/su2code/TestCases...u2mesh_per.su2
Thanks.
aman_baig is offline   Reply With Quote
distortion, giles, inlet, su2
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
Inlet Boundary profile for compressible flow uday sarkar FLUENT 1 November 20, 2015 09:24
3d velocity profile at velocity inlet swethaprakash FLUENT 3 September 1, 2015 02:10
3D pipe flow :: how to create non uniform inlet profile. thess FLUENT 1 May 30, 2014 02:43
Pressure Inlet Boundary Condition Profile arapha FLUENT 0 April 4, 2011 16:23
