Home > Forums > Software User Forums > SU2
Error: CSysSolve linear solver diverged
Old   November 19, 2020, 07:39
Default Error: CSysSolve linear solver diverged
mdsar is on a distinguished road
Hello everybody, I am trying to run a turbulent simulation with RANS solver and the same error keeps showing up:
Error in "void CSysSolve<ScalarType>::ModGramSchmidt(int, su2matrix<ScalarType>&, std::vector<CSysVector<ScalarType> >&) const [with ScalarType = double; su2matrix<ScalarType> = C2DContainer<long unsigned int, double, (StorageType)0, 64, 0, 0>]
FGRMES orthogonalization failed, linear solver diverged
I have already tried to change the CFL number, the slope limiter, the type of linear solver, convergence criteria and all the other parameters, but nothing works.
Does anyone have an idea of what might be happening here?
Thanks in advanced
mdsar is offline   Reply With Quote
Old   November 28, 2020, 23:43
Amit
aero_amit is on a distinguished road
Is it happening at the start or after few iterations ?
Make sure that your mesh is of acceptable quality and boundary conditions are correctly applied (at times mesh quality causes such divergence issue). Having said that, give a try to -
LINEAR_SOLVER= BCGSTAB
LINEAR_SOLVER_PREC= ILU
LINEAR_SOLVER_ITER= 5 or 10 (if needed) (In one case, these setting helped me to overcome the similar issue)
You can also try first order simulation followed by second order (restart from first) and see if it helps. Also switch off the multigrid (if turned on).
aero_amit is offline   Reply With Quote
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 06:32
how to modify fvScheme to converge? immortality OpenFOAM Running, Solving & CFD 15 January 16, 2013 13:06
