Wind Turbine Simulation using Multiple Reference Frame |
February 21, 2018, 08:54 |
Ghifari Adam Faza
Rep Power: 9 |
Hi all,
I'm totally new to SU2. I want to analyze torque output from wind turbine. According to some references, this work can be done using multi reference frame with one stationary domain and one rotary domain inside the stationary domain. Does this case can be done in SU2? Because I didn't see any test case file that similar with this case. Or this simulation can be done by using only Single Reference Frame like the cardonna-tung test case? Do you have any suggestions? Thanks in advance Ghifari |
mrf, su2, wind turbine |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Torque of wind turbine simulation | caohan | FLUENT | 8 | August 11, 2014 23:01 |
Single Reference Frame (SRF) or Multiple Reference Frame (MRF) | aminem | FLUENT | 2 | June 18, 2014 16:41 |
Wind Turbine + MRF (Multiple Reference Frame) | abolfazl | FLUENT | 8 | May 28, 2013 07:44 |
