Home > Forums > Software User Forums > SU2
How to combine multiple meshes and create multi zone mesh
Old   December 26, 2020, 12:05
Default How to combine multiple meshes and create multi zone mesh
koray is on a distinguished road
Dear SU2 Community
Currently, I am trying to figure out how to run a multi-row turbomachinery problem. I went through the test cases to see the structure. However the way that the grid was built, is not explained in there.
I need to prepare a multi zone simulation with a single mesh file input. Even, when I combine multiple rows of mesh (I tend to start with only two rows, to see how thing work, for now) in a single file, when I try to read it with SU2_CFD, it says the mesh has only one zone.
There is a Python file, merge.py, that may help but I am not sure. Up to now I created grid files in commercial software and export them in CGNS format. Time to time, I tried to convert and manipulate the grid in Gmsh. Once, I also used SU2_DEF to indirectly convert the file format.
Anyways, I couldn't succeed. Any comment will be appreciated. Many thanks for your help.
koray is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[mesh manipulation] Multiple overlapping meshes koala OpenFOAM Meshing & Mesh Conversion 1 February 1, 2017 05:53
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Other] 2D hex mesh on multi element airfoil Verfblikje OpenFOAM Meshing & Mesh Conversion 0 January 19, 2012 10:55
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
