Home > Forums > Software User Forums > SU2
SU2 v.7.0.8 cannot solve expansion region that was solved by using v.6.1.0
Old   February 16, 2021, 07:42
Question SU2 v.7.0.8 cannot solve expansion region that was solved by using v.6.1.0
Hüseyin Emre
aeronautics is on a distinguished road
Dear all,
I have been trying to solve a supersonic flow domain around an aircraft with SU2 v.7.0.8 that was solved before with SU2 v6.1.0 and results were validated. I have adapted the .cfg file from v6 to v7 without any change in solvers, multigrid etc.. However, the solution I have obtained by using v7 has yielded non-physical points at the downstream of the aft where Mach number goes up to 1800. The region behind this non-physical region has been solved almost the same as in v6.
This is the non-physical solution I've got. The aircraft is attached to wind tunnel sting. I've rescaled the Mach interval as 1.6-1.8 in the image. Freestream Mach is 1.7.
This is the mesh around the region. Aft of the aircraft (has relatively higher diameter) and sting (has relatively lower diameter) can be seen.
I'm appending the .cfg file.
config_fluid_v7.txt
What am I doing wrong? What could be the possible problem(s) and solution(s)? Any kind of help is appreciated. Thank you all in advance.
Huseyin Emre
aeronautics is offline   Reply With Quote
Old   February 16, 2021, 09:36
pcg
Pedro Gomes
pcg is on a distinguished road
Some of the things that changed:
Implementation of Euler and Symmetry boundaries, to improve them for viscous flows.
How the CFL adaption works.
And I believe the reference length for limiters was fixed at one, so you might need to multiply the Venkat constant by the reference length manually.
I recommend using the adaptive CFL strategy, even if you don't go higher than 15 it can reduce CFL in more challenging regions and possibly improve stability.
With multigrid I never use damping factors higher than 0.75.
pcg is offline   Reply With Quote
Old   February 16, 2021, 10:40
Smile
Hüseyin Emre
Thank you Pedro for your answer! I will try your suggestions and then let you know results.
Edit:
I've used adaptive CFL, multigrid damping factors of 0.75 and different limiter coefficients. Despite residuals has decreased about 0.7, I couldn't avoid non-physical solutions.
Last edited by aeronautics; February 17, 2021 at 10:19. Reason: Update about new solutions
Old   February 18, 2021, 06:43
Hüseyin Emre
I've overcome the issue with non-physical points. I don't know exactly why yet I think the problem was aroused from Roe scheme. I changed convective scheme to AUSM, adjusted multigrid damping factors to 0.75 and activated adaptive CFL then I could be able to get an accurate result.
expansion, non-physical, su2 v7, supersonic
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 04:15
Define velocity profile in fully develpoed region to solve energy equation haghgoo_reza OpenFOAM Programming & Development 0 September 22, 2013 20:19
Can SU2 solve the blast wave problem? newmancfd SU2 2 May 13, 2013 03:33
How can I solve at the interface region K. Baker FLUENT 0 April 3, 2007 03:39
