The adjoint equation in the discrete adjoint solver |
July 16, 2021, 04:47 |
Zhen ZHANG
Rep Power: 7 |
Hi all,
I recently studied the discrete adjoint solver because I want to add some space varying design variables. I also learned the CoDi package. Here are my understanding and questions. Assuming f is the objective function, g is the control equation, p is the design variable, and x is the flow variable. In an adjoint problem, we want to get df/dp. Let f_p be the partial derivative (f_p=partial f/partial p). We get df/dp=f_p+lambda^T*g_p where lambda is the adjoint variable and satisfies (g_x)^T*lambda=-(f_x)^T But in the solver, after starting recording, we register the solution and variables as the input, set dependencies, direct run, register the solution and the objective function as the output, and stop recording. Q1: why do we need to register the solution of the direct solver as the output? Now they are both input and output. And then in CDiscAdjSinglezoneDriver::Run(), we initialize the adjoint of the direct solver using the adjoint solver solution of the last step, set the derivative of the objective function as 1.0, compute the adjoint, extract derivatives of the solution and variables. Q2: What are the derivatives of the solution and variables here? In the reverse mode and with the obj func derivative set to 1.0, they should be partial f/partial(). Is that right? Q3: What does this iteration do? How does it solve the above adjoint equation? Maybe there are some mistakes in the statement due to my limited understanding. I am grateful if you point them out. Thank you! |
July 16, 2021, 05:24 |
Zhen ZHANG
Rep Power: 7 |
Add a question:
What is the calculated derivative of the direct solver's solution, i.e. the solution of the discrete adjoint solver? Why does it differ from what we set to it in the function iteration->InitializeAdjoint() of CDiscAdjSinglezoneDriver::Run()? |
July 16, 2021, 06:04 |
Pedro Gomes
Rep Power: 13 |
Your description is based on g being a residual function, i.e. that converges to zero.
However, in SU2 g is a fixed-point iterator for the solution variables (hence both input and output). The entire process was very well explained just 2 days ago here https://su2foundation.org/su2conference2021/ https://drive.google.com/file/d/18Kq...deB4pzfqR/view There will be a recording of Tobias' presentation at some point. See also the initial implementation paper https://bibbase.org/network/publicat...thodinsu2-2016 |
July 16, 2021, 07:59 |
Zhen ZHANG
Rep Power: 7 |
Thank you! I will read these materials.
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
RANS discrete adjoint oscillating | pgdelaserna | SU2 | 3 | August 25, 2019 04:32 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
A question about discrete adjoint method | Thomas | Main CFD Forum | 3 | August 9, 2006 12:37 |
