Turbulent channel with a bump - SU2 Cp problem |
July 19, 2021, 04:08 |
Pedro Paulo
Rep Power: 4 |
Hi everyone,
I am simulating the turbulent channel with a bump using SU2. The same one in this repository: https://github.com/su2code/VandV/blo...rb_bump_sa.cfg I am using the grids from the NASA website: https://turbmodels.larc.nasa.gov/bump_grids.html The original .cgf file in the mentioned repository is for Mach 0.20. When changing the Mach to 0.21, I update the BC using the isentropic flow equations. (Pt/Po = 1.031211844 & Ttot/To = 1.00882, for Mach = 0.21) So that the updated BC for Mach 0.21 in the .cfg file are: % Velocity inlet marker MARKER_INLET= ( inlet, 302.646, 70816.204742, 1.0, 0.0, 0.0 ) % % Pressure outlet marker MARKER_OUTLET= ( outlet, 68672.8 ) -------------------------------------------------------------------- The simulation converges, however, the Cp values does not make sense when I do that. What else should I change in the .cfg file to simulate Mach 0.21? |
July 19, 2021, 05:28 |
Pedro Paulo
Rep Power: 4 |
Problem solved!
Unfortunately there is no way to delete the post. |
July 23, 2021, 04:41 |
na
Rep Power: 7 |
Hi, glad you solved your problem
If you don't mind, maybe you can post your solution here briefly, it might help others to understand their problems best, Tobi |
cp values, su2, turbulent channel w bump |
Turbulent transition in channel flow | yansheng | STAR-CCM+ | 11 | June 16, 2016 09:05 |
Calculate statistics of Turbulent channel flow with LES | sjwon1991 | Main CFD Forum | 2 | May 10, 2016 23:31 |
LES of Turbulent Channel Flow; increased flux for some models? | Selvinus | Main CFD Forum | 14 | September 29, 2015 05:15 |
Turbulent Separation problem | fluidmechanics | FLUENT | 1 | September 7, 2015 13:59 |
LES: Turbulent Channel Flow without initial solution (BC) | DaSh | OpenFOAM Running, Solving & CFD | 21 | February 8, 2015 16:09 |
