LOW Mach simulation over NACA0012 wing, problem with stall |
September 2, 2021, 07:13 |
charan
Rep Power: 4 |
Hi everyone,
I am trying to simulate NACA 0012 wing in m=0.03 and Reynold number =129000. i have been using ROE. below is cfg which i am using. sst is not at all showing stall but some what sa is showing stall at AOA=30 which quite unusually. please help me what solver type, liner solver, preconditioner should be used in this cases, where i am doing the mistake thank you in advance SOLVER= RANS KIND_TURB_MODEL= SST INNER_ITER= 3000 CONV_FIELD= DRAG CONV_RESIDUAL_MINVAL= -3 CONV_STARTITER= 10 CONV_CAUCHY_ELEMS= 100 CONV_CAUCHY_EPS= 1E-10 MACH_NUMBER= 0.03871 AOA= 10.0 INIT_OPTION= REYNOLDS FREESTREAM_OPTION= TEMPERATURE_FS FREESTREAM_TEMPERATURE= 284.9 REYNOLDS_NUMBER= 129000 REYNOLDS_LENGTH= 0.15 NUM_METHOD_GRAD= GREEN_GAUSS CFL_NUMBER= 5.0 CFL_ADAPT= NO MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN MUSCL_TURB= YES SLOPE_LIMITER_TURB= VENKATAKRISHNAN VENKAT_LIMITER_COEFF= 0.05 LINEAR_SOLVER= FGMRES LINEAR_SOLVER_PREC= ILU LINEAR_SOLVER_ILU_FILL_IN= 0 LINEAR_SOLVER_ERROR= 1E-6 LINEAR_SOLVER_ITER= 5 LINEAR_SOLVER_SMOOTHER_RELAXATION= 1.0 MGLEVEL= 0 CONV_NUM_METHOD_FLOW= ROE ROE_LOW_DISSIPATION= FD ENTROPY_FIX_COEFF= 0.01 TIME_DISCRE_FLOW= EULER_IMPLICIT CONV_NUM_METHOD_TURB= SCALAR_UPWIND TIME_DISCRE_TURB= EULER_IMPLICIT CFL_REDUCTION_TURB= 1.0 |
September 6, 2021, 10:22 |
Amit
Rep Power: 12 |
First thing - Can you really predict stall with RANS models?
Coming to numerics - Mach number is very low (M=0.03), Roe scheme may not be suitable, try SLAU2 or AUSMPLUSUP instead alongwith USE_ACCURATE_FLUX_JACOBIANS=YES Try CFL up to 10 or so (do hit and trial +-), also try SLOPE_LIMITER_FLOW= VENKATAKRISHNAN_WANG Above may be more suitable settings, but consider the problem you are trying to solve in the first place ..... (update the findings nevertheless) |
September 6, 2021, 11:44 |
Low Mach simulation over NACA0012
charan
Rep Power: 4 |
thank you Amit for your reply, i came across transition model that is available in SU2 under incompressible rans using SA with BC transition mode. this has predicted the case almost near accurately with wind tunnel results. But i ahve a dobt, in Incompressible RANS +SA+BC is using 2nd order in flow equation but could able to manage only 1st order in turbulence equation (MUSCL_TRUB= NO). how much i should believe in these result, i also solve using Fluent, SU2 is outperforming Fluent in this accept. I am very doubtful with these results, please help me how i can assess this and also in 2 nd order its getting diverged. i want to know whether 2nd order is compulsory for this case or not. thanks you in advance
February 15, 2022, 05:52 |
#4 | |
Caserta
Rep Power: 4 |
February 15, 2022, 09:43 |
bigfoot
Rep Power: 17 |
August 1, 2023, 09:12 |
charan
Rep Power: 4 |
I have solved it using incompressible RANS in version 7.2 with BC transition model. the Y plus is close to 1 and i also did grid convergence study, by this procedure I could be able to get confidence on the results. For my problem, i prefer V7.2 than V7.5
Low Cl and Cd for a simple subsonic wing | Shruti Arumbakkam | SU2 | 1 | May 16, 2019 15:29 |
Low Mach number wing/body junction convergence | Zen | SU2 | 6 | May 3, 2019 04:51 |
Problem of vortex trajectory in the wake of a delta wing | Gohu8 | CFX | 11 | June 27, 2018 06:37 |
fluent subsonic wing analysis problem | fatihcoban | FLUENT | 0 | August 3, 2016 09:41 |
Low Mach Number Compressible Multiphase Flows | DarrenC | CFX | 10 | May 26, 2014 08:52 |
