Incompressible Euler Actuator Disk Simulation |
April 25, 2022, 04:59 |
I am new to SU2 and I am trying to simulate a blended body aircraft with an engine modelled as an actuator disk. I am using the solver for the incompressible Euler equations as my simulation has a very low mach number.
I know there are two versions of the actuator disk model and I am trying to compare the results that I obtain for both models. However, I cannot find a configuration that converges. I know there are two test cases with configuration files but I don't understand the meaning of some options. First of all I would like to ask If it is possible to use INC_EULER for the actuator disk. If it is possible does the pressure gauge condition that is needed for this kind of simulations change any parameter that is needed for the actuator disk (i.e VARIABLE_JUMP, Net Thrust,... conditions)? Secondly, my simulation has a symmetry condition so I am using "ENGINE_HALF_MODEL= YES", but I am not sure if using the symmetry condition for the whole aircraft is possible for this case as the engine itself has no symmetry condition with respect to the whole control volume. Moreover, I don't understand the meaning of both: % Highlite area to compute MFR (1 in by default) HIGHLITE_AREA= 1.374 % % Engine nu factor (SA model). ENGINE_NU_FACTOR= 0 |
April 25, 2022, 11:14 |
Pedro Gomes
Rep Power: 13 |
Hi Juan, the incompressible solver does not support actuator disk.
You may try the low Mach preconditioning for the compressible solver instead. |
April 26, 2022, 10:09 |
[GUIDE] Switching from incompressible to compressible simulation | gabrielfelix | OpenFOAM Running, Solving & CFD | 2 | September 3, 2021 12:45 |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 18:19 |
Two phase incompressible immiscible fluid flow simulation | sinhavivekananda318 | OpenFOAM Running, Solving & CFD | 0 | March 22, 2019 01:12 |
Transient Simulation in CFX | ashtonJ | CFX | 1 | September 28, 2018 01:18 |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 10:15 |
