Does SU2 implement any non-reflecting boundary condition? |
May 6, 2022, 09:52 |
Niccolò Tonioni
Rep Power: 4 |
Dear all,
Does SU2 implement any non-reflecting boundary condition? I'm currently trying to simulate the flow around a wall-mounted wing. The wind tunnel extends six chord lengths downstream of the airfoil. The idea is to replicate the experiment of Chow et al. [1] using SU2 RANS simulations. The domain geometry can be seen in the NASA turbulence model resource webpage [2]. One problem I encountered was the outflow boundary condition imposition. As observed by other authors [3], if a constant pressure boundary condition is imposed at the outflow, problems arise. This because, as said by Churchfield et al. in [3]: "a vortex has low pressure within its core, and the wingtip vortex being generated in this flow is convected downstream and out of the domain, problems arise when using a constant pressure outflow boundary. With the turbulence models that predict a less diffuse vortex, the vortex encounters a large adverse pressure gradient as it approaches the boundary, causing it to periodically burst, which does not allow for a steady-state solution." Since I only have found a constant pressure outflow condition on the SU2 documentation, I would like to ask if there is any other boundary condition already implemented which can deal with this type of flow. [1] https://arc.aiaa.org/doi/10.2514/2.1 [2] https://turbmodels.larc.nasa.gov/Oth...p0012_exp.html [3] https://arc.aiaa.org/doi/abs/10.2514...rnalCode=aiaaj |
May 7, 2022, 03:22 |
bigfoot
Yes, for compressible flows the Riemann boundary conditions are implemented and also Giles' boundary condition.
A tutorial for Riemann is here: https://su2code.github.io/tutorials/NICFD_nozzle/ Unfortunately these implementations are not well covered in the documentation. |
May 8, 2022, 13:38 |
#3 | |
Niccolò Tonioni
Rep Power: 4 |
Thank you very much for the answer. If one is interested I've found the two papers where they implement these boundary conditions. Riemann BC -> [1] page: 5-6 Giles BC -> [2] chapter: 3 [1] https://arc.aiaa.org/doi/10.2514/6.2015-2760 [2] https://repository.tudelft.nl/islandora/object/uuid:10797924-e37c-4328-a53a-55c5fdc464c3/datastream/OBJ/download |
July 7, 2022, 23:32 |
#4 | |
Jyoti Ranjan
Rep Power: 5 |
Thank you and regards, Jyoti |
Fatal overflow in linear solver. | iamnotfajar | CFX | 9 | October 28, 2020 04:47 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
