Home > Forums > Software User Forums > SU2
Error installing SU2 binaries with mpi support on windows
Old   February 9, 2021, 12:08
Default Error installing SU2 binaries with mpi support on windows
Bradley Craig
Creg is on a distinguished road
Upon instaling the SU2 binaries with mpi support and installing the required mpi files, I go to run my simulation with mpiexec -n 4 SU2_CFD ...... and 4 instances of SU2 begin in serial.
SU2 works absolutely fine in serial and I have ran a multitude of successful sims in the past this way so I assume theres an error with my mpi installation.
Does anyone have any idea what the problem could be?
Thanks in advance
Creg is offline   Reply With Quote
Old   February 9, 2021, 14:15
pcg
Pedro Gomes
pcg is on a distinguished road
That is usually caused by a mismatch between MPI versions.
Try to use the exact versions mentioned in the documentation.
pcg is offline   Reply With Quote
Old   February 10, 2021, 15:11
Bradley Craig
Thank you for the reply, I have used MS MPI v10.1.2, which is what is stated for SU2 7.1.0 so it should be fine in this respsect I think.
Do you happen to know of any other things that could cause this problem?
Thank you
Old   May 31, 2022, 09:57
jim
Jim gigi is on a distinguished road
Hello Creg,
I ran into the same problem just like you did, i wonder if you have resolve this problem yet.
Thanks,
best, JIM GIGI
Jim gigi is offline   Reply With Quote
mpi parallel, su2, windows 10
SU2 Installation for Windows 8 cacatoire SU2 Installation 1 August 14, 2020 12:07
SU2 Installation on Windows 32 bit niddaas SU2 Installation 3 May 6, 2016 17:03
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
SUPPORT FOR WINDOWS NT PLEASE! Mr. Lomil Main CFD Forum 3 November 3, 2003 09:11
