Home > Forums > Software User Forums > SU2
No marker found for fluid in config file
Old   March 14, 2023, 10:38
Default No marker found for fluid in config file
Kamran
Kamranh01 is on a distinguished road
Hi, I am able to get my mesh and config file to run on my laptop perfectly fine but when I try to replicate the sim on my pc I get the following error: saying that there is no definition for the marker FLUID which is the physical volume I have assigned in my mesh. I can't get my simulation to run what is the solution to this?
Kamranh01 is offline   Reply With Quote
Old   March 14, 2023, 22:54
pcg
Pedro Gomes
pcg is on a distinguished road
Maybe you did something different and exported all elements from gmsh? Or used a different version of gmsh?
pcg is offline   Reply With Quote
Old   April 1, 2023, 14:37
Sem
sjhbosmans is on a distinguished road
If you use an earlier version of GMSH it will be fixed.
sjhbosmans is offline   Reply With Quote
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
