Applying Temperature Distribution on Wall in SU2 |
November 25, 2023, 22:07 |
Sean
Rep Power: 2 |
Hello everyone, I need guidance on applying a temperature distribution on a wall. Could someone please provide the procedure or point me to relevant documentation?
November 25, 2023, 22:35 |
na
Rep Power: 7 |
You want to use the python wrapper
Please take a look at TestCases/py_wrapper/custom_heat_flux/run_ad.py and probably better TestCases/py_wrapper/custom_load_fea/run.py and take it from there. The code is from the custom_load_fea case and does eseentially what you want - which is to apply a spatially varying temperature BC. Code:
# Apply a load based on the coordinates. if nVertex > 0: MarkerCoords = SU2Driver.MarkerCoordinates(MarkerID) L = 0.5 dx = L / 16 # known from mesh settings in this case. for iVertex in range(nVertex): x = MarkerCoords(iVertex, 0) nodalForce = (2 * x / L) * dx # Half load due to half dx on first and last node. if abs(x) < 1e-6 or abs(x - L) < 1e-6: nodalForce = nodalForce / 2 SU2Driver.SetMarkerCustomFEALoad(MarkerID, iVertex, (0, nodalForce)) |
March 29, 2024, 04:44 |
#3 | |
Sean
Rep Power: 2 |
To provide more context and allow for a better understanding of the problem, I have prepared a comprehensive package containing the following: Configuration file Mesh file Temperature data file Python script for setting the boundary condition and running the simulation You can access the files package through this link:https://drive.google.com/drive/folde...usp=drive_link Could you please look into it and please lend some help. I will be grateful. |
Divergence in AMG solver! | marina | FLUENT | 20 | August 1, 2020 11:30 |
A question related to writing expression for (htc)Heat transfer coefficient | Hamda | CFX | 11 | April 17, 2020 00:57 |
Can't Get Temperature distribution in Solids in Fluent (Pipe cooling) | Bobby Charlton | FLUENT | 0 | December 31, 2019 19:07 |
How To Calculate Average Heat Transfer Coefficient in CFD-Post? | Shomaz ul Haq | CFX | 16 | November 24, 2019 18:57 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
