The result calculated using SU2_NEMO is incorrect |
December 28, 2023, 02:51 |
Liming Yang
Rep Power: 2 |
Hello all,
I am trying to calculate the example of HEG Cylinder from paper《SU2-NEMO: An Open-Source Framework for High-Mach Nonequilibrium Multi-Species Flows》, but I still can't get the correct result. Here are my grid files and configuration files, the residuals can be reduced to a very small order of magnitude, but compared to the existing results, it is obviously not correct. My temperature cloud map is shown in the top half of the image, and the correct result should be what the bottom half of the picture looks like. It seems like a lot of people have done similar calculations, so I'm not quite sure what went wrong. All the suggestions will be helpful, thank you very much. |
December 28, 2023, 02:53 |
#2 | |
Liming Yang
Rep Power: 2 |
January 9, 2024, 10:16 |
Peter Lysdahl Bęk
Rep Power: 4 |
Hello
I have just looked at the article you are referring to, and it seems that your boundary conditions differ slightly. Maybe this is the case? (it seems that you have different freestream pressure and temperature) I am new to SU2 so this is just a guess /Peter |
March 14, 2024, 20:12 |
AN
Rep Power: 2 |
Hello, CFDWhite!I found out that someone had asked about HEG before me!
I am also troubled by the HEG cylinder in that article. Have you finished the calculation of HEG now? If you have finished it, may I ask you some questions? K.M |
TKE calculated from dissipation rate not matching with that calculated from Spectrum | rdemyan | Main CFD Forum | 7 | August 11, 2023 11:36 |
buoyantBoussineqPimpleFoam Gravity Current | Bish | OpenFOAM | 0 | February 1, 2018 09:36 |
[Workbench] Current result file may not contain requested result data | zhizhuo | ANSYS Meshing & Geometry | 0 | December 13, 2017 04:18 |
Incorrect result from autodesk lab project falcon...plz guide... | addy01 | Autodesk Simulation CFD | 5 | March 3, 2013 07:16 |
LiftDrag utility from v12 to v141 | cfdphil | OpenFOAM Running, Solving & CFD | 2 | December 5, 2007 05:49 |
